Originally Posted By: CATERHAM
Originally Posted By: Indydriver
For what nearly everyone on this site uses motor oil for, all will do a comparable job. If you can find something on sale for $4.50-$5.00/qt then buy it. Otherwise, you're wasting money.
I don't entirely disagree with you but you might have a different opinion if you had an oil pressure gauge in you vehicles.
The first time I ran the Toyota 0W-20 I was shocked at how low the oil pressure was on start-up at room temperature. When I switched to the Idemitsu 0W-20 I was disappointed that is was quite a bit heavier although it is likely lighter than ever other 20wt oil available. Without an OP gauge I would have been totally blind to the difference.
I don't have a real op gauge in my 2002 F-150 but my winter starts in -0F* are quiet using Motorcraft 5W-20 and the Motorcraft FL820S oil filter. My truck sits outside 24/7. Maybe I'm losing some cold start mpg but my truck is a pig with mpg so it's not noticable. To me as long as the cold starts are noiseless then all is well with the oil and filter.
Whimsey
Whimsey
