Older Subarus do not have “smart” charging systems so wondered if the charge voltage on our Outbacks would be sufficient. Kind of late to that party since we’ve been using AGM for 10 years….
Plugged a voltmeter into a 12V plug. It hit 14.8V at first start, dropped to 14.3 over the next few minutes.
Odyssey owner’s manual states they require 14.7V to charge fully. 12.84V at battery is fully charged.
I'm pretty sure if you check it will also weigh more than the other two by a bit.
Rip the top off the two and you'll find the plates on the odyssey are thinner and use more interior space of the case they'll this TPPL (thin plate pure lead)
The odyssey in my titan is 16 years old now, and only ever got an AGM charge profile randomly when I used the odd maintainer that had that.
90% of the time it gets maintained at 14.3 on a non AGM Optimate 6.
I have killed them through mistakes and the new ones are the same weight as the older ones.
