- Joined
- Feb 7, 2025
- Messages
- 30
I drive a 2024 Mazda 3 2.5T AWD and is currently a little over 3,000 miles with two oil changes so far (one at 500 miles and one at 3,000 miles). Early changes were to get break-in material out. Eventually, I will get a used oil analysis done but it's currently too low mileage to have confidence in having a normal used oil analysis. The maintenance schedule of this car says 10,000 miles or 12 months under normal service and 5,000 miles or 6 months under severe service. I would put my car under severe service for several reasons:
1. Live in the upper midwest with very cold winters that last for several months
2. Almost always idle for two to three minutes before I drive to let the engine settle from a cold start in winter
3. Take a lot of short trips with lots of stop-and-go traffic with very infrequent longer trips
4. Well... it's turbo direct injected
For more context, I've only used Mobil 1 ESP 5w30 for the two oil changes so far and will eventually switch over to Valvoline XL-III 5w30, which I see as basically equivalent oil (lots of the same important specs/ approvals/etc.) but cheaper overall with the discounts from Valvoline Global. I expect an average of 3,000 miles annually so it makes me unsure when I should roughly be changing the oil. Changing oil every 6 months with 1,500 miles would seem to me unnecessary and overly cautious. I understand that used oil analysis would expose the truth better here but I'm gonna wait out for more mileage on the engine before doing them.
With all that said, can I confidently guess that 3,000 miles annual change is sufficient for TGDI engine longevity? This car is going to stay with me till it dies so I care about longevity but also don't want to waste what I would consider high-quality oils unnecessarily to appease the 6 months interval while not even closely hitting the 5,000 mile marker. I am asking from a general viewpoint as I understand TGDI engines differ from brand to brand and it'd be insanity to assume all TGDI engines are created equal. However, if you happen to know more specifically about this TGDI engine concerning OCIs and used oil analysis, it'd be welcome information. If I am missing any pertinent context, please let me know. Otherwise, answer away.
