Jim Rogers
Thread starter
- Joined
- Apr 4, 2023
- Messages
- 179
Similar situation and thoughts.
I have a Grand Caravan with the 3.8 V6 (just a bored/stroked 3.3). I've ran a 2200 mile OCI and FCI over 2 years and the filter and UOA looked fine. It was a Wix oil filter.
There is no doubt that, at a minimum, I will go two years (from my usual annual changes) on both the oil and filter. That would be a 2-year, 3,000 mi O/FCI. I think there is plenty of support to do that and wouldn't think twice about doing it.
I'm also fairly certain that I could do oil changes every 2 years, with the filter change happening every other oil change (i.e., OCI 2 years, 3,000 miles; FCI 4 years, 6,000 miles). I think there is enough indirect support here for that plan that it wouldn't represent any great risk.
To some extent, the only reason I used 6 years/9,000 miles for both oil and filter change intervals was to have a concrete number as to what I meant when I said "many years," and because I don't think I would go beyond those numbers.
Nothing magic about the 6 years, 9,000 miles benchmark for this conversation.
I have a BBC that runs the same PH30 size oil filter. I've used Purolator, Wix, ACDelco up to 3 year or so OCI/FCI but at very low mileage. I plan on doing a UOA in the Spring to see how the oil looks and change the filter. One thing I have considered is bumping up to a PH5 size filter. Fram does make an Ultra XG5 version of that filter (as you have mentioned, the XG30 is discontinued).
I would put a PH5 in a sbc if it was in a truck or regular car, but the Corvettes ride pretty low.
The PH30 is stock, and it's 4" long, which is perfect in the Corvette. The Wix 51069 I've been running is 4.3", which is acceptable but puts the bottom of the filter at about the same level as the pan.
A PH5 is 5.23" long, which means it will be an inch below the (already very low) pan. So, I don't think I want to risk that.
This person went 5 year OCI/FCI:
https://bobistheoilguy.com/forums/t...ock-m1-10w-30-5-year-oci.258463/#post-4190879
One concern I would have about the EG/TG is the fiber end caps. I have no issues running them for standard OCI over a year or so but have no idea what years would do to them, maybe nothing.
Thanks for that link-- I hadn't found that. Checking that guy's posts, he also says he has a car that he's gone 8 years (1,000/year) with the same filter. Said he planned to push it to 10 years!
Unfortunately, he never did any C&P's to determine the results of that experiment and stopped posting all together in 2018.
Looking at some of the related posts that I hadn't run into before, I have a sneaking suspicion that in a normally-functioning engine, time is really not all that big of a factor in filter life, and probably for oil life as well.
Plenty of hints here and there on this forum that there's no inherent problem with filter age (assuming the miles are low), and I'm not seeing any catastrophic reports that were due to a (low-mileage) filter failing because it was too old.
But, probably like everyone else, I'm not confident enough in simple "sneaking suspicions" to actually do the experiment to confirm it!
I could be wrong, but I don't think there is any risk associated with fiber end caps-- certainly not from time in the oil. I know they get a lot of negativity, but I think most practical experience says that they're fine. But, that's just another intuition on my part based-- don't have any solid proof that I'm right.
