Originally Posted By: Dad2leia
Aren't turbos also easier and more natural on an engine in terms of the boost? I realize that like javacontour said, there is the exhaust restriction, but from what I've learned, a small turbo is the most reliable AND safest way to get more out of a set size of engine, without too much fuss (other than figuring out where the heck you are going to put all of the plumbing involved..
I have a question on superchargers though. How are they regulated from constantly shoving boost into the engine. They are directly driven from the crankshaft, so wouldn't boost be directly related to rpms, instead of a spooling up?
Superchargers have bypass valves (roots style and screw style) that open if boost goes past a preset limit. They can be set up to open below a certain rpm and at cruise. Generally a positive displacement will stay roughly the same throughout the rpm range without the bypass.
A centrifugal blower like Vortech (looks like a big belt driven turbo) will continue to build more boost the higher the rpms go. People talk about turbo lag but on most of the centrifugal setups you don't get full boost until you hit redline.
Once the turbine is at speed, the turbo poses very little exhaust restriction. With VATN technology common on small diesels, the turbo is not a restriction at cruise. You basically have a variable size exhaust housing. It gets smaller through it's vanes for fast spool and gets larger for top end power and fuel economy.
Power lost from a turbo is only through exhaust restriction which doesn't put any extra strain on the internals.
A supercharger requires power to run. To get the same hp at the wheels, a supercharged engine will actually have to produce more power than a turbo because some of it gets eaten up by the blower. When looking into fuel requirements, for the same output supercharged motors will need more fuel. You engine has the stress of the extra power eaten up by the blower but you will never see it at the wheels.
I've got 20,000 miles on my car in it's current setup, even drove it 210 miles a day for work for a month with 0 problems. Not many people can honestly say they drive a 600hp small displacement V6 210miles round trip with no problems. I credit the turbo with some of this because it allowed me to build the rest of the motor fairly mild and rely on the boost for power.
