Originally Posted By: rationull
Originally Posted By: ShiningArcanine
From what I have read, I have come to believe that V6 engines have technological advantages over I6 engines ...
This piqued my interest. What technological advantages are you citing here? An I6 has more main bearings, and is much better balanced than a V6. It only has one cylinder head (and one head gasket), only requires one set of cams (assuming OHC), and can use a shorter timing chain (again, assuming OHC).
The only technical disadvantages I can see are that a longer head, cam, and crankshaft might be more prone to warpage or breaking but it doesn't seem like that's been a huge problem historically.
As stated above, clearly the V6 has great packaging advantages, but I'm curious as to what technological advantages you see here.
I had been under the impression from what I had read online more than a year ago that V engines gave better performance than equivalent inline engines. I had also been under the impression that smaller engines give lower performance and as an engine becomes smaller, the fuel economy increases. Therefore it seemed logical that a V engine could give better fuel economy than an inline engine while delievering the same horsepower. To me, that makes it technologically superior.
Originally Posted By: BarkerMan
To compare a V6 to an I6 is worthless. There are a lot of V6's out there and hardly any I6's. Also as stated there are many V6 models out there that offer a similar model with an I4. If you are like me and do all your own maintenance most of the V6 models will scare you away. Some of the regular maintenance on V6 cars is beyond acceptable.
I am working on a Biochemistry/Computer Science Double Major Chemistry/Mathematics Double Minor. On computer review sites, they do apples to apples comparisons with only one factor changing. Scientific experiments strive to minimize all differences between the control and experiment such that the only thing that varies is the variable that is being studied.
As far as what is technological advantageous is concerned, a I4 to V6 comparison cannot yield any information that would enable you to form a table where you can claim two directions to be superior on some basis and the opposite directions to be inferior on the same basis. An example of this is the periodic table in terms of electronegativity, where generally speaking, moving left and/or up across the table yields atoms of higher electronegativity and moving right and/or down across table yields atoms of lower electronegativity.
By the way, I think that when considering conventional automotive technologies, a V4 engine is optimal. I am not an mechanical engineer, but I imagine that a V4 engine could be placed with the V facing the front and back of the car rather than the sides as my Toyota Avalon's V6 engine faces. Doing that should allow easy access to all of the spark plugs and manifolds, making spark plug changes much easier than they are in my Avalon (which needs to be brought to the dealership for them) and placing both of the manifolds within access, rather than just one.
