Nissan Pathfinder - Blackstone Oil Analysis
Texas
Just received my oil analysis AND an interesting email in response to my question about syntetic vs. syntetic blend.
2005 Nissan Pathfinder v6
Oil Use Interval: 5,542mi
First, the report:
This is a nice report for your Pathfinder as it crosses the 100,000-mile mark. Wear metals are low and in correct proportion to each other when you compare this sample to universal averages. Those averages show typical wear levels for this type of engine after about 5,600 miles on the oil. Silicon could be abrasive dirt so it never hurts to check the air filtration system. With the low wear here though, we're thinking it's probably a harmless sealer or additive. The trace of fuel won't hurt anything. Try 7,500 miles on the next oil.
Second, here's my question after receiving the report: "The analysis in this report was on a synthetic blend. I just switched to Mobil 1 full synthetic. Would you still recommend 7,500mi or could/should I go longer? Also, does time matter as my wife no longer works and it will likely take more than 12 months to get 7,500 miles on this vehicle."
Blackstone response:
"Thanks for the email. Both the synthetic and syn blend should be able to handle the 7,500 miles. We don't see much difference in wear or longevity of the oil between the blends and full synthetics. Time on the oil really doesn't matter a whole lot. We have customers that don't drive much who keep the oil in use 2 or 3 years, sometimes longer and it's fine. Hope that helps. Let me know if you have any other questions."
If you continue doing UOA's, check the wear AND TBN of the Mobil 1 against the blend you were using.
You didn't say what the speced viscosity is nor the new Mobil 1's viscosity.
I would say most Mobil 1 or Pennzoil synthetic oils can probably go 7500 miles.
" Both the synthetic and syn blend should be able to handle the 7,500 miles. We don't see much difference in wear or longevity of the oil between the blends and full synthetics."
Now BITOG can be closed!
Sorry.
Analysis: 5W-30 Kendall Synthetic Blend
Switched to: 5w-30 Mobil 1 (regular stuff not the high mileage or EP)
I'm sure there's some basis for Blackstone's comment, but Toyota says OCIs can be 10,000 miles with synthetic but only 5,000 with conventional. I think I'd be more inclined to agree with Toyota.
OP,
Would you be willing to post your analysis in the UOA section? If we can see the numbers it may be easier to point you in the right direction.
Originally Posted By: REDDOG
OP,
I'm still fairly new here. How do I post the results if they are in pdf format? And yes, I can post on a different forum.
Type them up.
MI/HR on Oil: 5,542
MI/HR on Unit: 100,907
Sample Date: 3/23/2013
Make Up Oil Added: 0 qts
ELEMENT / 1ST COLUMN / LAST COLUMN (UNIVER AVE)
ALUMINUM 3 / 4
CHROMIUM 0 / 1
IRON 8 / 11
COPPER 2 / 8
LEAD 1 / 3
TIN 4 / 1
MOLYBDENUM 76 / 76
NICKEL 0 / 0
MANGANESE 0 / 1
SILVER 0 / 0
TITANIUM 93 / 1
POTASSIUM 2 / 2
BORON 38 / 47
SILICON 48 / 18
SODIUM 8 / 45
CALCIUM 2518 / 2324
MAGNESIUM 13 / 126
PHOSPHORUS 734 / 681
ZINC 851 / 805
BARIUM 0 / 0
SUS Viscosity @ 210°F: 57.6 / 54-61
cSt Viscosity @ 100°C: 9.53 / 8.5-10.8
Flashpoint in °F: 365 / >365
Fuel %: TR / Antifreeze %: 0 / 0
Water %: 0 / 0
Insolubles %: 0.4 / TBN
TAN
ISO Code
