You don't know what you don't know... that's all I am gonna say.Considering very large motors are near 60%
Nice engine … see them on some generator sets once in a while …Carnot theoretical is 100% if output leaves at absolute zero and is meaningless in terms of comparing production engine designs at ambient temperatures.
What way would you prefer it be measured?
Wärtsilä 31 (2015) Is around 165g/kwhr which is beyond 50%
What efficiency would you attribute to 165g/kwhr?
Whaaat?Carnot theoretical is 100%
Anthony, my 2017 Nissan Frontier with the 2.5 liter engine and 5 speed manual gearbox has needed a battery at the 2 year mark, a viscous fan clutch at the 2 year mark, complete adjustment of emergency brake on the passenger side of vehicle when new, and the assembly was incomplete. The factory battery has only a 1 year warranty and the fan clutch has a 36,000 mile warranty that I had surpassed by a mere 1200 miles at time of failure. Therefore, no warranty coverage was offered.What issues has your Frontier had?
Nevermind, I just Googled it myself. Half a Buick V6, 250 hp, 51 mpg.
https://www.motortrend.com/how-to/hrdp-1009-what-ever-happened-to-smokeys-hot-vapor-engine/
The nuts that attach the front strut on the passenger side were not tightened down, the windshield washer fluid pump was not plugged in, the grommet for the door wiring was not installed, and I'm sure I had a half dozen more issues that I tended to. The vehicle was very poorly assembled and quality control at the Mississippi facility did not catch any of the issues. Then, the vehicle was PDI'd at the dealership and they caught none of the assembly issues (not speaking of the battery and fan clutch).
These photos were taken within the first week of ownership. I purchased the vehicle in Nashville, TN., and live in Atlanta, Ga. and the dealership experience has been so horrible that I just dealt with the issues rather than subjecting myself to the incompetence of the circus clowns at the local franchise.
Nissan will NEVER receive another penny of mine.
Wow. I definitely understand your frustration. I purchased this Titan and Frontier in 2015. Neither have had any problems. Both have over 90k and both also built in Canton. Maybe just a rough week when they built yours lol.Anthony, my 2017 Nissan Frontier with the 2.5 liter engine and 5 speed manual gearbox has needed a battery at the 2 year mark, a viscous fan clutch at the 2 year mark, complete adjustment of emergency brake on the passenger side of vehicle when new, and the assembly was incomplete. The factory battery has only a 1 year warranty and the fan clutch has a 36,000 mile warranty that I had surpassed by a mere 1200 miles at time of failure. Therefore, no warranty coverage was offered.
The direct injected engines are designed to do exactly that lean burn with help of controlled injection pattern.
Toyota's current hybrid internal-combustion engines run at 42% efficiency, a number that should increase with their next-generation engines. If Nissan has a special prototype engine that runs at 46% efficiency to charge a battery, that sounds reasonable. They are saying that they will add an additional 4% efficiency using a waste-heat recovery system, which is typically a thermoelectric generator (TEG), and that sounds plausible, too.It's a lie, marketing. That's not thermal efficiency, that e-Power is a thermal motor driving a generator.
No real life thermal cycle can be more efficient than Carnot theoretical cycle.
https://en.wikipedia.org/wiki/Carnot_cycle
The engine itself is 50% efficient.It's a lie, marketing. That's not thermal efficiency, that e-Power is a thermal motor driving a generator.
Slight correction there: the waste-heat recovery system is a thermoelectric generator (TEG); so, it is not really part of the internal-combustion engine (ICE). However, since the sole purpose of this engine is to recharge a battery, it effectively adds up to the ICE efficiency. Nevertheless, the heat engine itself, which generates the mechanical energy, is said to have a 46% efficiency in this case.The engine itself is 50% efficient.
"the most efficient current production engines are closer to 40% thermal efficiency.
in testing, Nissan said it achieved 43% thermal efficiency just by diluting the mixture (using exhaust-gas recirculation), 46% when using lean combustion (meaning more air and less fuel), and 50% when operating the engine at a fixed rpm and load, with waste-heat recovery technologies."
https://www.greencarreports.com/new...iciency-from-engine-for-e-power-hybrid-system
No, it is not. The assembly engine/recovery/electric motor might be (but I doubt it will be in reality).The engine itself is 50% efficient.
Is that a hybrid system they are talking about?However, since the sole purpose of this engine is to recharge a battery, it effectively adds up to the ICE efficiency.
What is meant by the Ghetto Crown, sounds very racist to me ??Around here Kia, Hyundai, and Chevrolet wear the ghetto crown.
It means it's what the drug addicts/poor people driveWhat is meant by the Ghetto Crown, sounds very racist to me ??
You haven’t heard of Getto Corp? Crown is the flagship.
Nissan cars are junk. I have one.You should ask yourself why there are so many Nissan is junk comments. It might open some doors into truth for you.
