2002 Nissan Sentra 1.8L4,man trans
3qts Redline 5w-30/ 12oz Auto-RX/26oz LC/4 oil filters used,1 nissan,2 wix,1 M1
40235 total miles
14187 oil miles- 1 year service
Auto-RX w/M1-110 for liquid filtration 1500 miles
LC used at 2oz per qt initial fill, then 1to3 oz every 1000 miles.
6000 miles into interval we had a silicon issue from a jarring blow to engine and exhaust system,and dirt ingression. Si to 90 ppm. Changed AF and oil filter using LC and Auto-RX and dropped Si to 26 ppm, rose to 29 ppm at end of test.
al 3 normal to low
ca 1519 depleted
cr 1 low to normal
cu 11 slight elevation Auto-RX dropped this from 15 peak
fe 39 slight elevation ARX dropped from 42 peak
pb 11 slight elevation, no change from trend but stable.
mg 10 slight depletion of oil add
mo 307 depleted
p 649 depleted
k 17 normal
si elevated 29 see note above, this is affecting all wear values.
na 15 normal oil add
sn low, a major drop using Auto-RX ! peak of 6 ppm
zn 769 depleted
soot/solids 13 LOW
oxd 111 or 55.5% normal RL and Auto-RX oxd levels, 40 or 20% normal for conventional oils in this test engine
Nit 98 or 49% normal for duration, 40% normal burns hot.
Sulfur 26 LC and FP cleans up the crappy gas here! LOW.
W,A,F negative, none, perfect
V100cSt 11.9 Starts at 11.2 well within limits considering 3 qt capacity and dirt ingression.
TAN 1.8 oil starts at 0.1, this is a change indicator for us. Auto-Rx raises this during cleaning and would drop if filter changed and topped a bit, LC will drop this as well as oxidation.
TBN 3.0 plenty of residual add remaining, mostly base oil influence as adds deplete. 10.0 VOA dropped as low as 2.0 during test.
Conclusion : Redline oil is one of the strongest PCMO's available and If I could have filtered this oil to < 10 um it could still be used with metered LC usage and top up with FF change.
I am very keen to see the Bob Winters Escort Si drop with the gulf coast bypass filter clean his Si levels.
LC and Auto-RX seemed to have worked quite well together although more formal testing is required to confirm. LC controls both Oxidation, vis increase, it also has a FM capability that seems to be dependent on insolubles/soot levels.TAN can be moderated as well with LC.
Auto-RX "liquid filter" affectation did have a positive effect in conjunction with M1 oil filter to stop or drop wear values. More testing required for confirmation.
Auto-RX was used in cleaning phase for 2000 miles using a wix oil filter. Filtering phase 1500 miles at end of test.
Oil changed to GC 0w-30 with M1 -110 oil filter and I will share test data with the BITOG site at that time.
[ March 08, 2004, 12:25 AM: Message edited by: Terry ]
40235 total miles
al 3 normal to low
ca 1519 depleted
cr 1 low to normal
mo 307 depleted
p 649 depleted
k 17 normal
zn 769 depleted
soot/solids 13 LOW
