I have a Kohler Timecutter that typically runs a pair of RC12YCs. I had a Rotary maintenance pack that came with a pair of NGK BKR5Es which are almost a direct replacement that I have been using. Can I use NGK BPR5ES (I have a bunch for the Honda GCV160) which are pretty similar beside the 'P' projected insulator type which is quite a bit larger sticking out of the engine. Heat rating are both '5' (Medium) and thread reach 'E' is .75, 3/4"... Thoughts?
Seat: Flat | Seat: Flat |
Thread Size: 14mm | Thread Size: 14mm |
Heat Range: 5 | Heat Range: 5 |
Resistor Type: Yes | Resistor Type: Yes |
Hex Size (in): 5/8 Inch | Hex Size (in): 13/16 Inch |
Washer Included: Yes | Washer Included: Yes |
Preset Gap (in): 0.036 Inch | Preset Gap (in): 0.036 Inch |
Thread Reach (in): 0.750 Inch | Thread Reach (in): 0.750 Inch |
Ground Configuration: Standard | Ground Configuration: Standard |
Ground Electrode Core Material: Nickel | Ground Electrode Core Material: Nickel |
Number Of Ground Electrodes: 1 | Number Of Ground Electrodes: 1 |
Center Electrode Core Material: Copper | Center Electrode Core Material: Copper |
Center Electrode Tip Material: Nickel | Center Electrode Tip Material: Nickel |
Ground Electrode Tip Design: Standard | Ground Electrode Tip Design: Standard |
Approximate Resistor Value (Ohm): 5000 Ohm | Approximate Resistor Value (Ohm): 5000 Ohm |
Insulator Height (mm): 50.5mm | Insulator Height (mm): 55mm |
Electrical Terminal Type: Non-Removable Nut | Electrical Terminal Type: Removable Nut |
Center Electrode Design: Standard | Center Electrode Design: Standard |
Service Number: BKR5E | Service Number: BPR5ES |
