I have received new zinc coated rotors that are supposed to be less prone to rusting.
A few years ago, while changing over to my winter tires/wheels, a couple of the wheels were stuck good to the raw iron rotors and required an uncomfortable number of smacks with a rubber mallet to free them.
Since then I have applied a light coating of nickel based anti-seize to the alloy wheel mounting surfaces - and have not had a repeat of the sticking.
Any ideas as to whether anything similar will be needed to prevent any galvanic corrosion between the coated rotors and the alloy wheels??
