Originally Posted by Red91
No one here was confusing the two warrens...and the relationship between Walmart and Warren distribution is pretty well a given in the Eastern half of the us, besides Florida. The new supertech bottles are of wd design and it would make little sense for Wal Mart to buy bottles from them but not oil, since Warren distribution is the largest independent refiner and bottler of oil in the united States.
Originally Posted by 53' Stude
Red91: I rarely read any of Gokhan advice. Not worth it
And no one said that you were confusing the Warren Distribution/WPP with Warren Oil... I pointed it out not for you but for whom this information isn't obvious. So, no need to get edgy.
You're probably right that the new ribbed bottle is currently only used by Warren Distribution.
However, check this out:
Plugging the UPC bar codes into:
http://msds.walmartstores.com/
You get:
MSDS - SuperTech (PLP) / (Warren Distribution, Inc.)
MSDS - SUPER TECH (PLP) Archived / (Warren Distribution, Inc.)
MSDS - SUPERTECH FULL SYNTHETIC 5W30 (PLP) A... / (CITGO Petroleum Corporation)
MSDS - SuperTech DEXOS 5W-20, SuperTech DEXOS 5w30 (PLP) / (Warren Distribution, Inc.)
So, the last three bottles are the same but one of them is made by Citgo and the other two are made by Warren Distribution.
Interesting note: The Super Tech High-Mileage Full Synthetic 0W-20 is a top-rated GTL oil -- thumbs up to Warren Distribution!
Code
Rank BOQI DV-35 NOACK Date purchased Oil
1 > 85 ? ? N/A Mobil 1 Extended Performance 0W-20
2 84.3 4,110 10.10 2014/02/16 Mobil1 Synthetic API SN, ILSAC GF-5, SAE 0W-20 motor oil
3 83.3 3,928 10.70 2015/12/28 Mobil 1 Full Synthetic SAE 0W-20 dexos1
4 81.9 4,316 9.90 2018/01/25 Genuine Nissan Full Synthetic SAE 0W-20 Motor Oil
5 80.4 5,122 8.50 Amsoil PDS AMSOIL Signature Series Synthetic Motor Oil 0W-20 (ASM)
6 78.2 4,182 10.70 2017/03/06 Mobil 1 Advanced Fuel Economy Full Synthetic SAE 0W-20 dexos1
7 66.1 4,102 12.90 2018/01/24 Genuine Toyota Synthetic SAE 0W-20
8 59.0 5,929 10.00 2018/03/12 SuperTech High Mileage Full Synthetic SAE 0W-20 Motor Oil
9 57.8 5,884 10.30 2017/03/06 Pennzoil Platinum Full Synthetic with PurePlus� Technology SAE 0W-20 dexos1
10 57.1 6,068 10.10 2015/12/28 Pennzoil Platinum Full Synthetic SAE 0W-20 dexos1
11 54.9 5,958 10.70 2014/02/06 Quaker State Synthetic API SN, ILSAC GF-5, SAE 0W-20 motor oil
12 54.0 5,448 11.90 2015/04/01 Beck/Arnley Premium OE Fully Synthetic SAE 0W-20
13 54.0 5,949 10.90 2018/03/12 Royal Purple Synthetic Oil SAE 0W-20 High Performance Motor Oil
14 53.2 5,721 11.50 2015/12/28 Valvoline Full Synthetic SYNPower SAE 0W-20
15 53.0 5,006 13.20 2015/12/28 SuperS SuperSyn Full Synthetic SAE 0W-20
16 51.9 5,819 11.60 2017/03/06 Valvoline Full Synthetic SYNPower SAE 0W-20 dexos1
17 51.7 5,642 12.00 2018/01/24 ACDelco Synthetic SAE 0W-20
18 51.2 5,342 12.80 2017/12/09 Honda Full Synthetic SAE 0W-20 Motor Oil
19 49.8 5,537 12.70 2015/12/28 Castrol Edge Full Synthetic SAE 0W-20 dexos1
20 49.5 5,996 11.80 2017/03/07 O'Reilly SAE 0W-20 Full Synthetic dexos1 Motor Oil
21 48.6 5,451 13.20 2014/08/14 Castrol Edge Synthetic Motor Oil API SN, ILSAC GF-5, SAE 0W-20 motor oil
22 47.6 5,658 13.00 2015/07/27 STARFIRE SAE 0W-20 Full Synthetic dexos1
23 47.2 5,657 13.10 2014/02/07 Pronto Supreme API SN, ILSAC GF-5, SAE 0W-20 motor oil
24 47.2 4,981 14.90 2014/08/25 Starfire Motor Oil API SN, ILSAC GF-5, SAE 0W-20 motor oil
25 46.2 5,786 13.10 2015/12/28 ProLine Full Synthetic SAE 0W-20 dexos1
26 45.6 5,113 15.00 2014/12/01 i-Sint XL 4AM Synthetic SAE 0W-20, API SN, ILSAC GF-5
27 44.9 5,647 13.80 2017/12/09 i-Sint XL 4AM Synthetic Engine Oil SAE 0W-20
28 43.5 6,138 13.10 2017/03/06 STP SYN Full Synthetic SAE 0W-20 dexos1
29 43.1 5,723 14.20 2016/01/25 AMSOIL Synthetic OE SAE 0W-20 Motor Oil
30 41.8 5,814 14.40 2014/02/07 MAG1 API SN, ILSAC GF-5, SAE 0W-20 motor oil
31 39.7 6,163 14.30 2014/08/11 Federated Motor Oil API SN, ILSAC GF-5, SAE 0W-20 motor oil
List of 0W-20 oils by base-oil-quality index (BOQI): 2018
Also, when I searched Super Tech, I've seen many made by Shell (SOPUS) and many other companies:
MSDS - Super Tech Premium DOT 3 Brake Fluid (PLP)&n... / (Warren Distribution, Inc.)
MSDS - Super Tech Power Steering Fluid with Leak Stop (PLP)
MSDS - Super Tech Gas Treatment (PLP) Archived... / (Warren Distribution, Inc.)
MSDS - Super Tech Fuel Injector & Carburetor Cleaner (PLP)
MSDS - Super Tech Fuel Injector Cleaner Super Concentrate (PLP)
MSDS - Super Tech White Grease (PLP) Archived
MSDS - WM452 Super Tech Lubricant 8 OZ. (PLP) R... / (Technical Chemical Co.)
MSDS - Super Tech SAE 10w30 Motor Oil (PLP) / (Warren Distribution, Inc.)
MSDS - WM2417 Super Tech Non-Chlorinated Brake Cleaner 14.5 OZ. / (Technical Chemical Co.)
MSDS - Super Tech -30° Premium Windshield Wash and Deicer (PLP)
MSDS - Super Tech -20° Windshield Wash (PLP) Archiv... / (Old World Industires)
MSDS - Super Tech 0° Windshield Wash (PLP) Archive... / (Old World Industires)
MSDS - Super Tech +32° Windshield Wash (PLP) Archiv... / (Old World Industires)
MSDS - Super Tech Zero F Windshield Washer Fluid (PLP) A... / (Splash Products)
MSDS - Super Tech +30F Windshield Washer Fluid (PLP) Arch... / (South/Win, Ltd)
MSDS - Super Tech Full Synthetic 10W30 Archived / (SOPUS Products)
MSDS - Super Tech SAE 5W-20 Synthetic Blend Motor Oil (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech DOT 3 Brake Fluid (PLP) Arch... / (Warren Distribution, Inc.)
MSDS - Super Tech Oil Treatment (PLP) Archived / (ITW Global Brands)
MSDS - Super Tech High Mileage Automatic Transmission Fluid (PLP)
MSDS - Super Tech Gas Treatment (PLP) / (Technical Chemical Co.)
MSDS - Super Tech Fuel Injector Cleaner (PLP) / (Technical Chemical Co.)
MSDS - SUPER TECH 5W20 (PLP) Archived / (SOPUS Products)
MSDS - Super Tech Concentrated Fuel Inj. Cleaner (PLP) / (Technical Chemical Co.)
MSDS - 01589 Super Tech DOT 3 Brake Fluid 12 FL.OZ. (PLP) / (Technical Chemical Co.)
MSDS - 91326 Super Tech DOT 3 Brake Fluid 32 FL.OZ. (PLP) / (Technical Chemical Co.)
MSDS - Super Tech Power Steering Fluid, 12 oz. (PLP)&n... / (Technical Chemical Co.)
MSDS - 69429 Super Tech Power Steering Fluid 32 FL.OZ. (PLP) / (Technical Chemical Co.)
MSDS - Super Tech Marine 80w90 Gear Oil (PLP) ... / (Warren Distribution, Inc.)
MSDS - Super Tech Marine Power Trim & Tilt & Fluid (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Fuel Injector Cleaner (PLP) ... / (Warren Distribution, Inc.)
MSDS - Super Tech ATF Archived / (SOPUS Products)
MSDS - Super Tech Marine TC-W3 (PLP) Archived / (SOPUS Products)
MSDS - SUPER TECH 15W40 (PLP) Archived / (SOPUS Products)
MSDS - SUPER TECH 10W30 (PLP) Archived / (SOPUS Products)
MSDS - SUPER TECH 5W30 (PLP) Archived / (SOPUS Products)
MSDS - SUPER TECH High Mileage 10W40 (PLP) Archived
MSDS - SUPER TECH High Mileage 10W30 (PLP) Archived
MSDS - SUPER TECH 20W50 (PLP) Archived / (SOPUS Products)
MSDS - Super Tech 10W40 (PLP) Archived / (SOPUS Products)
MSDS - Super Tech Wash and Wax 100 oz. (PLP) Archived
MSDS - Super Tech Wash and Wax 20 oz. (PLP) Archived
MSDS - SuperTech High Mileage 5w30 (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Mercon V ATF (PLP) Archived (Warren Distribution, Inc.)
MSDS - Super Tech Dexron VI ATF (PLP) Archived... / (Warren Distribution, Inc.)
MSDS - WM4642 Super Tech Carburetor Cleaner 12.5 OZ. / (Technical Chemical Co.)
MSDS - Super Tech 10W30 Motor Oil 5QT (PLP) Recert... / (Delfin Group USA LLC)
MSDS - Super Tech 10W30 Motor Oil QT (PLP) Recerti... / (Delfin Group USA LLC)
MSDS - Super Tech 10W40 Motor Oil 5QT (PLP) Recert... / (Delfin Group USA LLC)
MSDS - SUPER TECH (PLP) Archived / (Perfectdata)
MSDS - Super Tech Multi-Vehicle ATF (PLP) Arch... / (Warren Distribution, Inc.)
MSDS - Super Tech ATF+4 (PLP) Archived / (Warren Distribution, Inc.)
MSDS - Super Tech 75W90 (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech 85W140 (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech 80W90 (PLP) Recertification... / (Warren Distribution, Inc.)
MSDS - SUPER TECH 5W20 MOTOR OIL (PLP) Archi... / (CITGO Petroleum Corporation)
MSDS - SUPER TECH HD 30 (PLP) Archived
MSDS - SUPER TECH TYPE F ATF (PLP) Archived (CITGO Petroleum Corporation)
MSDS - SUPER TECH MULTI-VEHICLE ATF (PLP) Ar... / (CITGO Petroleum Corporation)
MSDS - Super Tech Antifreeze/Coolant (PLP) ... / (Prestone Products Corporation)
MSDS - Super Tech Ext Life Antifreeze & Coolant (PLP)&n... / (Old World Industires)
MSDS - Super Tech 2-Cycle Engine Oil (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech 303 Tractor Hydraulic & Transmission Fluid (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Moly Lithium Grease (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech -20 Windshield Wash (PLP) Archived (DYK Automotive LLC)
MSDS - Super Tech +32 Wash (PLP) Archived / (DYK Automotive LLC)
MSDS - Super Tech Starting Fluid (PLP) / (Perfectdata)
MSDS - Super Tech Brake Parts Cleaner (PLP) / (Perfectdata)
MSDS - Super Tech Carburetor Cleaner (PLP) / (Perfectdata)
MSDS - Super Tech Lubricant / (Perfectdata)
MSDS - Super Tech -20 Washer Fluid (PLP) / (South/Win, Ltd)
MSDS - WM451 SUPER TECH ENGINE DEGREASER (PLP) / (Technical Chemical Co.)
MSDS - Super Tech Marine Grease (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Heavy Duty SAE 30 Bar & Chain Oil (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Multi-Duty Complex Grease (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech General Purpose Grease (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Full Synthetic SAE 75W-140 Gear Lubricant (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Automatic Transmission Fluid ATF+4 (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Fuel Injector & Carburertor Cleaner, Super Tech Super Concent... / (Warren Distribution, Inc.)
MSDS - Super Tech Automatic Transmission Dexron VI (PLP)
MSDS - Super Tech DOT 3 Brake Fluid (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Non-Detergent 30 Lubricating Oil (PLP)
MSDS - Super Tech High Mileage SAE 5W-20 Motor Oil (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Universal 2-Cycle Engine Oil (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech Full Synthetic 2-Cycle Engine Oil (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech 4-Cycle Tractor & Lawnmower SAE 30 Engine Oil (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech 4-Cycle Tractor & Lawnmower SAE 10w30 Engine Oil (PLP) / (Warren Distribution, Inc.)
MSDS - Super Tech / (Spectrum Brands GAC)
MSDS - Super Tech DOT 3 Brake Fluid 1 Gallon (PLP) / (Technical Chemical Co.)
MSDS - SUPER TECH (PLP) Archived / (South/Win, Ltd)
MSDS - 46670 Super Tech CA Compliant Brake Parts Cleaner 14.5 OZ. (PLP) / (Technical Chemical Co.)
MSDS - 46671 Super Tech CA Compliant Carburetor Cleaner Spray 12.5 OZ. (PLP) / (Technical Chemical Co.)
MSDS - 42348 Super Tech Engine Starting Fluid 11 OZ. (PLP) / (Technical Chemical Co.)
MSDS - Private Label Washer Fluid - Super Tech -25 Wash (PLP) / (South/Win, Ltd)
MSDS - Private label, washer fluid - Super Tech Bug Remover (PLP) / (South/Win, Ltd)
MSDS - Super Tech Fuel Injector Treatment and Upper Cylinder Treatment / (Armored AutoGroup)
MSDS - Super Tech Oil Stabilizer / (Armored AutoGroup)
MSDS - Super Tech Diesel Exhaust Fluid / (Smittys Supply Inc)
MSDS - SUPER TECH DEICER / (Perfectdata)
MSDS - Super Tech Oil Stabilizer / (DYK Automotive LLC)
MSDS - Super Tech Fuel Treatment / (DYK Automotive LLC)
MSDS - SuperTech Gas Line AntiFreeze (PLP) Recertificati... / (South/Win LTD.)
MSDS - SuperTech Gas Line AntiFreeze 4PK (PLP) Recertifi... / (South/Win LTD.)
MSDS - SuperTech Premium Water Remover (PLP) Recertifica... / (South/Win LTD.)
MSDS - SuperTech Premium Water Remover 4PK (PLP) Recerti... / (South/Win LTD.)
MSDS - SuperTech (PLP) / (Old World Industires)
MSDS - SuperTech (PLP) / (South/Win, Ltd)
MSDS - Supertech -20F Windshield Wash Recertification
MSDS - Supertech +32F Windshield Wash / (Splash Products)
MSDS - SuperTech -50F RV & Marine Antifreeze / (Splash Products)
MSDS - SuperTech (PLP) Recertification
MSDS - SUPERTECH 10W30 (PLP) Archived... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH 10W40 MOTOR OIL (PLP) Archi... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH 5W30 (PLP) Archived / (CITGO Petroleum Corporation)
MSDS - SUPERTECH FULL SYNTHETIC 10W30 (PLP) ... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH HIGH MILEAGE 10W40 (PLP) Ar... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH HIGH MILEAGE 10W30 (PLP) Ar... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH HIGH MILEAGE 5W30 (PLP) Arc... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH DEXRON VI ATF (PLP) Archive... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH HIGH MILEAGE ATF (PLP) Arch... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH MERCON V ATF (PLP) Archived... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH DEXRON III MERCON ATF (PLP) ... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH ATF +3/4 (PLP) Archived
MSDS - SUPERTECH BAR AND CHAIN OIL 30 (PLP) ... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH HAND CLEANER 190950 Archived / (PERMATEX)
MSDS - Supertech Antifreeze Coolant / (Prestone Products Corporation)
MSDS - Supertech Prediluted 50/50 Antifreeze Coolant / (Prestone Products Corporation)
MSDS - SuperTech (PLP) / (Perfectdata)
MSDS - SUPERTECH HEAVY DUTY 15W40 (PLP) Arch... / (CITGO Petroleum Corporation)
MSDS - SuperTech R&O Anti-Wear Hydraulic Fluid (PLP)
MSDS - SuperTech 303 Tractor & Hydraulic Fluid (PLP)
MSDS - SuperTech High Performance SAE 80W-90 Gear Lubricant (PLP)
MSDS - SuperTech High Performance SAE 85W-140 Gear Lubricant (PLP) (CITGO Petroleum Corporation)
MSDS - SuperTech Synthetic Blend SAE 75W-90 Gear Lubricant (PLP)
MSDS - SuperTech Synthetic SAE 75W-140 Gear Lubricant (PLP)
MSDS - SuperTech Heavy Duty Tractor Hydraulic & Transmission Fluid (PLP)
MSDS - SuperTech Marine TC-W3 2-Cycle Outboard Engine Oil (PLP)
MSDS - SuperTech Marine SAE 80W-90 Gear Lubricant (PLP)
MSDS - SuperTech Marine Power Trim & Tilt Fluid (PLP)
MSDS - SuperTech Universal Precise Mix 2-Cycle Engine Oil (PLP)
MSDS - SuperTech SAE 30 Non-Detergent Oil (PLP)&n... / (CITGO Petroleum Corporation)
MSDS - SuperTech Synthetic Multi-Vehicle Low Viscosity Automatic Transmission... / (CITGO Petroleum Corporation)
MSDS - SuperTech High Mileage Motor Oil SAE 5W-20 (PLP)
MSDS - SuperTech 4-Cycle Engine Oil SAE 30 (PLP)&... / (CITGO Petroleum Corporation)
MSDS - SuperTech 4-Cycle Engine Oil SAE 10w30 (PLP)
MSDS - SuperTech Universal 2-Cycle Engine Oil (PLP)
MSDS - SuperTech Refrigerent R134 (PLP)&nbs... / (Test Rite International Co., Ltd.)
MSDS - SuperTech Universal Full Synthetic 2-Cycle Engine Oil (PLP) (CITGO Petroleum Corporation)
MSDS - SUPERTECH MULTI-DUTY COMPLEX GREASE (PLP)&... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH GENERAL PURPOSE GREASE (PLP)&nbs... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH MARINE GREASE (PLP) Archive... / (CITGO Petroleum Corporation)
MSDS - SUPERTECH MOLY GREASE (PLP) Archived (CITGO Petroleum Corporation)
MSDS - Supertech Ethanol Treatment (PLP) / (Gold Eagle Co)
MSDS - Supertech Motor Treatment (PLP) / (Gold Eagle Co)
MSDS - SuperTech De-Icer with Rain Repeller WW -25F / (Splash Products)
MSDS - SuperTech Heavy Duty Diesel Motor Oil, SAE 30 (PLP)
MSDS - SuperTech Full synthetic Motor Oil SAE 5W-20 (PLP)
MSDS - SuperTech (PLP) Recertification... / (Warren Distribution, Inc.)
MSDS - SuperTech (PLP) / (Technical Chemical Co.)
MSDS - WalMart SuperTech Transmission Leak Stopper / (Gold Eagle Co)
MSDS - SuperTech / (Guangdong Appscomm Co., Ltd.)
MSDS - SuperTech (PLP) / (Armored AutoGroup)
MSDS - SuperTech (PLP) / (TSI Products Inc)
MSDS - SuperTech (PLP) / (KOST USA, Inc.)
