New to BITOG here.
Full disclosure - I've always used Mobil 1 on all my cars long before I knew about BITOG so pardon my lack of knowledge. I'm pretty brand-loyal and up until a few years ago I've been using the regular Mobil 1 Synthetic you can get at Walmart. I would consider myself an advanced amateur when it comes to working on cars - short of removing an engine and its accessories like a/c, alternator and transmission, I've done pretty much everything else.
But the knowledge of some people here is quite intimidating and admittedly, beyond whats on paper, the fine print and details of oil are still all greek to me. I have limited knowledge of oil - I just know enough to be safe as far as I am concerned. So, I've been a long time lurker for quite a few years after finding this site and only recently did I join to ask for some advice.
So here's where I stand.
I currently maintain the vehicles in my household, and my father's household, and my brother's household. Its a total of 8 cars I do regular maintenance. And up until a few years ago, I've began being more picky and careful about the oil I use on them.
Here is what the current state is (oil,filter, mileage) for each car.
My household-
2012 Lancer ES hatch - Mobil 1 Advanced Fuel Economy 0w30, Fram XG-series filter, 115k mi
2013 Lancer Evolution MR - Mobil 1 5w30 AP (last 2 oil changes were using the AP, previously used to be Mobil 1 Extended Performance 5w30), Mobil 1 Annual Protection filter, 686 mi
2015 Acura RDX (wife's) - Mobil 1 Extended Performance 5w20, Fram XG-series filter, 63k mi
Father's household-
2016 C7 Stingray - Mobil 1 5w30 Full Syn, OEM filter, 1100mi
2018 Expedition Limited - unchanged, still on OEM, 1500mi (prev replaced 2012 Explorer XLT, Mobil 1 Extended Performance 5w20 HM, Fram XG-series filter)
Brother's household-
2016 Fusion Sport - Valvoline 5W-20 Full Syn, Fram XG-series filter, 43k mi
2019 Fiesta ST - Mobil 1 Extended Performance 5w20, OEM filter, 1800mi
2019 Flex non turbo - Valvoline 5W-20 Full Syn, Fram XG-series filter, 2300mi
> all the oil drain bolts except for the Expedition have been swapped out for magnetic ones.
So here's where I would like to get some opinions. I've been procrastinating on doing a used oil analysis so that is on my list this year.
The Evo does not get driven a lot. It's my weekend car (my 3rd Evo, completely stock and unmolested, previous 2 were stock-ish). A few times in between oil changes I drive it a bit hard after getting it up to temp (I also wait for the Twin Clutch fluid to wrm up as well) to blow out the cobwebs. I've changed the oil on it every 6 months, roughly every 50 miles based on my mileage. I've always used Mobil 1 5w30 from day one, used Mobil 1 0W-40 a few times in 2015, and switched to Mobil 1 Extended Performance 5w30 until I just recently tried the AP formula since it went on sale and that's what it is on right now.
I know its not a broken in engine (well 600 miles is broken in per the factory), and I idle the engine under load (a/c) for 40-50 mins every so often. Plus the occasional spirited drive every now and then.
But with a toddler turning 2 this year, the past couple of years I've not been able to drive it as often so it sits if not idles under some load. Plus moved into a new place so fixing up the garage was my top priority. Last couple of oil changes using the AP formula I found very little to no varnish (that I can see through the oil fill hole) and the oil drained was almost still clear, like a light gold color. I know it is probably overkill since the engine does not see any load for extended periods. If anything I feel it gets heatsoaked idling.
So will using the EP (I plan to switch back once the sale expires) be more than enough? I know a used oil analysis will tell for sure, but based on the conditions (CA climate), what is known about the oil(s) used, the limited to no heavy load the engine gets, will that suffice? I guess I'm looking for peace of mind as well as some direction. keep in mind that since its been relegated as a sort of toy in the garage, I have the luxury to experiment on different oils every now and then and cost (at least so far) has not been a problem.
Thank you for reading this far and I appreciate your input!
My household-
Father's household-
