Originally Posted By: bepperb
Every time you rotate tires on a front wheel drive car you are doing the exact opposite... you are putting the better tires (with less wear) on the front.
So I guess the question is what is the condition of the two not-new tires. If they are really worn I would agree and put them up front as to keep the dynamics safe. If they are relatively new and would have comparable traction I would put them in back so that over the next 10,000 miles all tires would become even and you could use a normal rotation pattern.
if you rotate your tires often enough they wont wear wonky and have 3/4 worn out ones and new looking ones.
If I had 2 half worn tires and 2 new tires.. I wouldnt mind the new tires in the front for spring/summer/fall provided the half worn tires werent prone to hydroplaning. (and equalize wear)
IN the winter you dont want [censored] tires in the rear.
That causes the whole left turn at intersection turns into a 360degree spin into car/pole
you have traction to go.. but with no grip in the rear you do donuts when trying to turn.
then again I still might like the worn ones out front.. and just replace them before winter.
