Hey all,
I just put some new tires on my Integra over the weekend, and had an alignment done right after by a different shop. I noticed that after they put the tires on, if I had the steering wheel perfectly centered and let go, the car would slowly pull to the left. If I turned the wheel to the right and let go, the car would continue to go straight until I moved the wheel again. I took it in to get an alignment done, and it's still doing the same thing. It's driving me nuts (perhaps because of my OCD) that my steering wheel is no longer centered, even though the car appears to drive straight. I'm going to take it back to the shop that did my alignment to see if there's anything they can do, but before that, any thoughts/ideas on why this might've happened? The first thing I plan to check after I get out of work is the tire pressures, though they look fine from my naked eye and I would've assumed they checked them while installing the tires. Any help would be much appreciated!
