Why would it not have the 3.5?
Restyled/new Tacoma with turbo 4 is 2024.
I think this is correct. I got my years wrong.
Its because toyota counts the 2024 model year as "available" in 2023. Stupid I know.I think this is correct. I got my years wrong.
That’s what I’m thinking too, combined with the hot IAT’s. OTT does not disable this mode in the tune.It's the timing. It's a tad too advanced.
LSPI is likely not going to occur in the Atkinson cycle mode with the delayed closing of the intake valve, unless the tune disables the simulated Atkinson cycle mode altogether
Correct.You have the 3.5 V6 in a 2023 Tacoma?
December or January for the new 2.4next year model, maybe in days actually, not exactly sure.
If this pinging started after the tune, I would uninstall the tune.That’s what I’m thinking too, combined with the hot IAT’s. OTT does not disable this mode in the tune.
E20 is fine, not much more than this. Open loop actually runs on the rich side. Again, it’s more tip in knock under partial acceleration. Not under WOT.Can we go back to the fuel choice? E20? Does the truck OM allow for E20?
Unless this is a flex fuel, you may be running it lean, which exacerbates any knocking tendency, even with added octane.
Pinging can destroy an engine. Bumping up the timing on a naturally aspirated engine usually doesn’t yield much HP, but it can tear up the pistons with pre-ignition.
Turbo tune is a different matter. Increased boost is generally low risk on an engine in decent shape.
No oil will make a difference for pinging caused by inappropriate spark timing.
I call that lugging the engine. Burn 93 octane and put your foot in it.Well, I’m assume it’s LSPI as it matches up with the definition from what I understand. Light throttle, low rpm, higher load. I’m watching the knock sensors via my OBD2 device / Toyota PID’s. This engine makes all its power at higher RPM for the most part. Tends not to happen if you are heavier on the throttle.
I’m actually running nearly 96 octane, but yes, it obviously rears its head at partial throttle. I was under the impression it may be oil droplets causing the pre-ignition but apparently not.I call that lugging the engine. Burn 93 octane and put your foot in it.
Almost everyone I’ve seen post UOA’s on 20 weight show higher levels of iron, copper, and aluminum. You can actually run up to 15w40I’ve run RGT, PUP, Amsoil (all 0w20) in my tuned ‘19 Tacoma 3.5 with no issues, but I haven’t checked for knock. I run 90 octane at high elevation, so not worried about it.
Planning on switching to HPL P+ 0w30 for my next change.
No issue at all.I just finished my personal break-in procedure on my 23 Tacoma V6 3.5. I switched to Mobil 1 European Formula 5w-40 at 200 miles, since then I have done 2 additional extractions. I’m also a big fan of Liqui Moly’s Cera Tec and just treated the motor at 1200 miles. It definitely helped smooth out the idle, this platform is not known to have this smoothest idle. I’m also tuned and the timing has been pumped up, this probably affects what I’m seeing on the knock sensors. Running e20 mixed with 93 or about 95.5 octane.
I have noticed this engine tends to have a bit tip-in knock or LSPI at initial acceleration. It’s pretty minor but I’m wondering is switching to a GF6 or GF6A oil would help with this. Maybe I’m making an issue out of nothing as the knock is pretty minor but I love seeing it stay at near 0. From what I understand, M1 EF is a very good formulation but do you experts think there is a better one? From the UOA’s I’ve seen 40 weight hot seems to offer some of the best wear metal reduction I’ve seen over 0w-20.
Who told you that E20 “is fine”?E20 is fine, not much more than this. Open loop actually runs on the rich side. Again, it’s more tip in knock under partial acceleration. Not under WOT.
He is trying to blow up an engine that already has very high compression by making it even higher.Who told you that E20 “is fine”?
Toyota says differently. This is your owners manual. Up to E15. DO NOT use any flex-fuel or gasoline that could contain more than 15% ethanol...
You’re not going to fix this with oil selection. The problem isn’t in your oil.
You’ve got an engine for which some knocking is normal (also, in your owners manual).
Then you tuned it.
Then you run on something that Toyota tells you not to use.
1:1000 in favor of Toyota Corporate, take it or leave it.Are we taking bets for how quickly Toyota is going to decline this guys warranty when his engine goes pop?
Issue isn't really if tuning a new car is good or bad. I tune my honda's right from the dealer. But this isn't a K motor, nor is it a 2ar or a 1zz or a 2j or a b series. Its a very delicate, highly strung, half atkison cycle, efficiency focused revision of the 2GR which granted, is a strong motor...was a strong motor.Tuning a brand new truck is not the best idea.
Especially in this case, it is not a performance vehicle by any means, and not intended to be. A tune will not turn a Tacoma into a Ferrari even if it increases power by 5% or "improves transmission shifting" or whatever reason people tune their newer vehicles. And let's face it, people only buy Tacomas over Colorados (for example) for their perceived reliability. The competition rides better, gets better MPG, and is nicer inside. But people pay the Toyota Tax for a Tacoma to get what has historically been one of the most reliable mid-size trucks on the road. And now OP ruined it by doing a tune and running the wrong fuel and now he wonders why it isn't running right!? Add in additives and completely different oil for no reason.Tuning a brand new truck is not the best idea.
I would say its more reliable than the competition, but the FKS is less reliable than the FE from the previous gen tacoma. There are plenty of people whose engines overheated and threw a rod out the side of the block in the FKS and that is because it was designed to be "more efficient" by being lighter, cheaper, and all the other eco friendly things compared to the old school version of the 2GR. Heck, its miles worse than the old 1GR in terms of longevity.Especially in this case, it is not a performance vehicle by any means, and not intended to be. A tune will not turn a Tacoma into a Ferrari even if it increases power by 5% or "improves transmission shifting" or whatever reason people tune their newer vehicles. And let's face it, people only buy Tacomas over Colorados (for example) for their perceived reliability. The competition rides better, gets better MPG, and is nicer inside. But people pay the Toyota Tax for a Tacoma to get what has historically been one of the most reliable mid-size trucks on the road. And now OP ruined it by doing a tune and running the wrong fuel and now he wonders why it isn't running right!? Add in additives and completely different oil for no reason.
