New PDS - Amsoil 0w-30
NJ
http://www.amsoil.com/storefront/tso.aspx
The only changes I notice are VW 503.00 and Mercedes 229.5 have been added. But as we've seen, looks like chemistry changes took place bc the last 2 or so used oil analysis came back with very little P/Zinc.
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
11.2
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
56.9
Viscosity Index (ASTM D-2270)
195
Cold Crank Simulator Apparent Viscosity @ -35°C, cP (ASTM D 2602)
5520
Borderline Pumping Temperature °C (°F) (ASTM D3829) -40 (-40)
Pour Point °C (°F) (ASTM D 92)
-54 (-65)
Flash Point °C (°F) (ASTM D 92)
226 (439)
Fire Point °C (°F) (ASTM D 92) 247 (477)
Noack Volatility (DIN 51581) 250°C for 1 hour, % weight loss 8.6
High Temperature/High Shear Viscosity cP, X°C, X s-1 (ASTM D4683) 3.4 A3 ?
Four-Ball Wear Test (ASTM D 4172: 40kgf, 150°C, 1800 rpm, 1 hr) Scar diameter, mm 0.374
Total Base Number
>11.0
[ March 22, 2005, 06:09 PM: Message edited by: buster ]
Thanks for the update...been checking their website. They must have just updated today. HTHS 3.4 and A3 rating...hmmm. Now if Mobil would just post their Mobil 1 Extended Performance PDS.
[ March 22, 2005, 07:47 PM: Message edited by: sully ]
Now if Mobil will post the Mobil 1 Extended Performance PDS.
Exactly. I still wish Mobil would make a thicker 0w-30, but as others have said, the market really doesn't call for it. The Amsoil and GC are the two best IMO.
*Last week they said the 21st they would be out. If not then, later this week they said. The 5000 are out.
These are the same "typical batch data" specs as this formulation has had for the past several years. So the high/low temp viscometrics haven't changed ....
Sully,
The HT/HS viscosity typically runs @ 3.5 Cp, +/- 0.1 Cp for this formulation - hence the A3 designation instead of A5. The previous spec sheet showed 11.3 Cst @ 100C and HT/HS of 3.5 Cp, just for comparison.
One thing different is that they have removed the VW 505.00 and ACEA "B4" diesel applications from the list. I'd speculate this is due to the updated additive chemistry and somewhat reduced Ca/Mg levels. So I'd recommend one of the Amsoil CI-4+ rated synlubes for VW TDI diesel engines and NOT this version of the Series 2000, 0w-30.
TS
