Hi all. I just purchased a brand new Kubota GR2010 lawn tractor powered by a 20 horsepower twin cylinder Kohler (pressure lube with a spin on filter). Although this tractor is brand new, it is a 2008 model, so my guess is that the factory fill oil has been sitting in the sump at the dealer for a year or more.
The Kubota manual states that the initial oil change should take place at the 50 hour mark. I am having trouble with this due to the fact that this oil is already a year old. On the other hand, this tractor only has a grand total of 3 hours on it.
I should state that cost is not deterring me from doing the initial oil change early. If I had my way, I would have done it already but I thought I would ask the experts here first.
So, I have purchased a brand-new NAPA Gold filter for this engine, and have available the following oils if I proceed with this early oil change:
1. 10W-40 Amsoil Motorcycle Oil (synthetic)
2. 10W-40 Mobil 1 4T Racing Motorcycle Oil (synthetic)
3. 10w30 (30) Amsoil Small Engine Oil (synthetic)
My plan was to change the oil right away using the NAPA Gold filter and one of the above oils. Then, I was going to do it again at the factory-recommended 50 hour mark with another new filter.
So, my question is: Should I proceed with this early change? Is this engine too new to run synthetic? (Mobil 1 says no, but I am not convinced)
Again, this isn't a cost question. I just want to make sure that I break this engine in properly. If it costs an extra 30 bucks to do it in an optimal manner, then I am happy. I just don't want to introduce synthetic too early if you guys figure I shouldn't.
I thank you for your suggestions in advance!
