borgward
I see it now. Page 11 - API Service Classification : SF, SG, SH, SJ or SL
I still use it on some of the machines that come through the shop for service. Briggs and Stratton Vanguard full syn 30. Vanguard has great pricing on all of their full syn products. It is blended by Citgo.Does anyone remember back in the 70's and 80's running SAE-30 in our mowers ? I used Castrol SAE-30 because it was the clearest oil that I found. A clearer oil is better, right?![]()
I'd run it at full throttle, so it does not overheat.I run it mostly at half speed.
Yes, as @spasm3 mentioned run it at full throttle. If you are switching on the PTO you could bring the throttle down halfway but then bring it back up.How many tanks fill ups before I change oil? Kawasaki FR652-V. Was not able to keep accurate time. I run it mostly at half speed.
On my kohler push mower engine it's easy to figure because it has one speed and takes 1 hour 15 minutes to use up a full tank.
Agreed.Yes, as @spasm3 mentioned run it at full throttle. If you are switching on the PTO you could bring the throttle down halfway but then bring it back up.
The "15w" and "50" are not "weights" or viscosity, they are categories designated by the SAE.Does 15w 50 go directly from 15 to 50 as soon as the engine warm up or does it go to an in between weight on a cooler day? What Engine temperature is the FR651-V designed to run at? What is considered too hot?
You can still find Castrol HD30 in many stores. I used it a few times in my Kawi V-twin and it worked as well as anything else.Does anyone remember back in the 70's and 80's running SAE-30 in our mowers ? I used Castrol SAE-30 because it was the clearest oil that I found. A clearer oil is better, right?![]()
As long as the cooling fins are clean, the operator will probably say "it's too hot to mow" before the engine will. Most of the oil viscosity charts in the engine owners manual go at least to 100F outdoor temperature.Does 15w 50 go directly from 15 to 50 as soon as the engine warm up or does it go to an in between weight on a cooler day? What Engine temperature is the FR651-V designed to run at? What is considered too hot?
Air cooled engines will run in a wide variety of temps, but their operating temps are linked directly to the ambient temps. That's a big reason why many members recommend a 40 or 50 grade oil for the heat of summer.What Engine temperature is the FR651-V designed to run at? What is considered too hot?
