In the "What's New" link for this 3.9L engine, GM says this:
"Variable intake manifold The variable intake manifold is an engine feature usually found only on high-cost, premium European performance cars, but the new manifold design is standard with the 3.9L V-6. The active air intake optimizes incoming airflow through a valve in the intake manifold. The valve creates longer or shorter intake tracts that correspond to desired engine-performance parameters. At low engine speeds, the valve creates a longer path for intake air, enhancing combustion efficiency and torque output. At higher engine speeds, the valve opens, creating a shorter air path for maximum power production."
Usually found on "high-cost, premium European performance cars"?? I suppose it depends on your definition of "usually".
Google IMRC (intake manifold runner control) and note that Ford has been using this on 4.6L V8s and the Duratec 2.5L and 3.0L engines since the early-mid 90s. Even my mom's old 1997 Ford Escort with it's 2.0L SOHC engine has "Split Port Induction" which is a different name for the same idea. (That "split port induction" along with the additional .1L of displacement boosted it's horsepower from 88HP to 110HP, with the old 1.9L SOHC getting 88HP).
I even ran across an article (which I wish I could find again) in some trade journal which explained that intake manifold runner control and it's variants can be used as an inexpensive way to make an older engine design produce more horsepower (which is clearly what Ford was doing with it in the 1997 Escort).
Speaking of that, I think it'd be really neat if there were an aftermarket intake manifold for the Ford 302 V8 that incorporated intake manifold runner control. It would need an electronic control to actuate it based on engine speed, but I think there are aftermarket "VTEC" controllers for the Honda crowd which could work, although it wouldn't be hard to design one.
I say this because (of the ones I've looked at) the aftermarket intake manifolds available for the 302 that give you higher RPM horsepower drop your low RPM torque. IMRC could give the best of both worlds.
