I know I make a few thread about home, I should just make all in one.
This is my very first house that I bought. I will start learning about maintained and general repair.
I got an home inspection come out and inspect the house. He came back with some issue need to look at.
My realtor asking the seller for repair, after a long talk back and forward. The seller decision is take some moneys off the house and I repair everything, I agree with that.
I will move in very soon and I would like some of the issue need to be taken care first. My budget is $2000
My water heater is not working. How much for a new water heater or should I go tank less. I'm talk about new unit install and labor
Here is what my inspection report say, please look at this and give some advice for cost guess estimate also who I need to call for each repair or some one that call do it all? The inspection told me the water heater and GFCI is main concern.
1:
The GFCI outlet at the master bathroom has hot and neutral reversed and it does not trip. “
2:
The A/C was functioning at the time of the inspection. Condenser - 2013
The main drain line under the sink at the hall bathroom is not connected.
The safe T switches of both A/C are missing. Need to insulate all the drains pipes
3:
Comments: The sink at the hall bathroom drains slow.
No true P trap under the sink at the hall bathroom. Should use the PVC pipes.
The P trap under the right sink at the master bathroom is in wrong position and it will not block the gas from the sewage
4.
Looks like the water heater is the original and the water is not that hot. I would recommend having the unit replaced if necessary. The drain pan and the drain line are missing.
1:
2:
3:
4.
