New filter for the 1.4T Ecotec
WA
My parents will be picking up a new Cruze in a few months. I was wondering if the new 1.4T Ecotec used the same filter has the other Ecotec's. I guess it doesn't. I found this filter on Napa's site. It looks to be longer then the the 7082 one.
With the new dexos 1 spec. I would imagine the OLM OCI will be 10K+.
That's the one from my 1.8VVT, also fits the Aveo.
I reuse it once for the 2x a year oil changes.
They are expensive, but I got a few Purolators from Advance on the 5q Edge w/filters OC deals. Iused a $10 off coupon and did a Castrol rebate....15q of Edge and 3 of those $10 filters for under $5 total.
PS look for the German ones, they are mixed in w/other mfgs.
My mom will look at a Cruze soon, to replace her 1996 Passat 4cyl. However, if she's ok w/a wagon I believe the Jetta SportsWagon will be the one.
So the 1.8 is already using this filter then? I wonder why GM wouldn't stick to the same filter size for the entire Ecotec lineup?
7674
Oil Filter Gasket O.D. (Inches) : 2.645"
Oil Filter Gasket O.D. (mm) : 67 mm
Oil Filter Gasket Thickness (Inches) : 0.135"
Oil Filter Gasket Thickness (mm) : 3 mm
Oil Filter Height (Inches) : 4.17"
Oil Filter Height (mm) : 106 mm
Oil Filter I.D. (Inches) : 1.023" B - 0.375" T
Oil Filter I.D. (mm) : 26 mm B - 10 mm T
Oil Filter O.D. (Inches) : 2.248"
Oil Filter O.D. (mm) : 57 mm
Oil Filter Style : Cartridge Lube Metal Free Oil Filter
7082
Oil Filter Height (Inches) : 3.51"
Oil Filter Height (mm) : 89.15 mm
Oil Filter I.D. (Inches) : 1.125"
Oil Filter I.D. (mm) : 28.58 mm
Oil Filter O.D. (Inches) : 2.41"
Oil Filter O.D. (mm) : 61.21 mm
It's a little taller.
Yes, it's used on the Korean Ecotecs. The 2.0/2.2/2.4 Ecotec is a completely different engine. Only thing that is the same is the Ecotec badge.
The 3800 found in many GM's here is called a Ecotec in the Australian apps.
