This past weekend installed some new rotors and pads on the Crown Vic. Noticed a little bit of squeaking noise as I'm driving. How long do you guys typically notice that the noise last before they're fully bed in?
all questions I had but I wanted to assume he knew how to correctly do a brake job.Did you clean the hubs where you mount the rotors? Did you need to spray brake cleaner on the rotors to take that oily surface off? Did you clean the calipers? How about lubing the ears of the pads and back of the pads?
Damped iron has some noise control properties. Most likely, the Bosch rotors were plain G3000 steel and the Hyundai rotors were not.When we put original hyundai (semi-metallic) pads on hyundai rotors, they were silent. If we used hyundai pads on Bosch rotors we got squeaking under braking. I don't know if the casting of the rotors was different, if they used a different material or what else it xould be but the squeaking never stopped unless either pads or discs got replaced (by bosch pads or oem discs).
I was gonna say this. And there are two sounds, squealing, and groaning, which are different.Squeaking is not part of the bed in process. As others have noted - something else needs to be revisited in the install.
