Originally Posted By: JimPghPA
You could use a radiator for an automatic in a standard transmission car, if it fits. Just do not connect anything to the two fittings for the transmission cooler on the radiator.
The thick puty form of JB-Weld is called PC-7
+1 on the radiator.
PC7 at least the older stuff is the same thickness as the JB Weld Putty but it doesn't hold up to the heat as well. I have some here and checked, the JB Weld is better for heat, unless PC7 has been reformulated in the last 2 years. HTH
+1 on the radiator.
