Tomorrow I plan on putting Advance Rotors and their Wearever PlatinumPremium Ceramic Brake Pads. Here is where I need guidance. I have done brakes on my 99 Saturn SL2 since buying it over 9 years ago. I learned to replace brakes on that car. Started with Duralast Rotors and Duralast Gold pads. Before installing third set of DG pads, I installed Centric rotors from Rock Auto. Started getting heavy pulsing, especially at highway speed. Then installed Raybestos Rotors and Cermic pads from Rock Auto. The problem returned after 5,000 miles are so. I read all the info available on brakes I could find. I decided to get NAPA's best rotors. I am thinking it is a rotor problem...or maybe a runnout problem. I cleaned hubs. Installed new guide and lock pins and new rubber inserts. Bought a dial indicator to measure runnout. That did not go so well so I spent more time cleaning small areas of rust on hubs. Reinstalled Raybestos pads with these rotors. Used Sly-Glyde for pins. Things were going good until recently. For 5,0000 miles no problem. I had new tires installed about 1,2000 miles ago. Read article last night about lug nut torque. I retorqued lugs last night. A few of them were extra tight. I could hear right brake and rotor had a high spot that went away after braking a few times. Vibration was reduced 50% or so after re-torque lugs. Looked at my service records. The heavy vibration tended to start 1000 to 2000 miles after tires were rotated or replaced. I called the shop this morning. They told me they use torque bars. How accurate are they? I remember going to another shop of same parent company and they stripped two lug nuts on a previous car. My plan is to bring torque wrench and breaker bar every time I have tire service. I am sure they will enjoy it when I check the torque in the parking lot. Guess I will not know if that is the problem until I try it consistently. Do you have recommendations on my brake job tomorrow? Due to my work schedule I rarely have a full day off and use my car at work. Otherwise I would have more of a wait and see attitude. I was going to take rotors back to Napa and get them changed out so I will be ready if the pulsation returns. Suggestions welcome. This has been a learning process. Rear brakes adjust manually 2,000 miles or so ago....
