Need quality oil filter for Honda 3.5 V6
Like this 'made in china' Nissan filter that destroyed the engine in my new 2014 Versa Note. Poor thing never had a chance. Cost me thousands in a trade at the selling Nissan dealer. I think I posted this at least 10 times over the years to get the point across, LOL
Looks o.k. on a quick glance, but can you spot what is wrong here? >
Looks like the filter element is too big for the can and might restrict flow.
As much as people on this forum (including myself) preoccupy themselves with things like filtration efficiency and bypass settings, construction quality is the single most important aspect of an oil filter. There's a lot that can go wrong with a filter: a burst can, leaky gasket, leaks from corrosion, internal obstructions, a missing bypass valve. Any of these things can cause oil starvation and kill an engine.
Even for a BITOG member, me thinks you obsess too much on the subject. But here's a relevant if partial list:
AC Delco PF2057
Baldwin B1402
Beck Arnley 041-8135
Bosch 3323
Champ PH2867
Denso 150-2006
Donaldson P502007
Driveworks DW4612
Ecogard Synthetic S4610
Fram XG7317
Hastings LF240
Luberfiner PH2867
K&N PS-1010
Mahle OC707
Mann ML1008
Mobil 1 M1-110
Motorcraft FL822
NAPA Gold 7356
Nippon 15400-PLM-A01A
Pennzoil Platinum HPZ-37
Premium Guard PG4612EX
Purolator Pure One PL14610
Ultra-8 3612910
Valvoline VO-106
Wix 57356
Yes, the fibre-composite end caps were a slip and close to an interference fit to the inside wall**. First cool day in first week of ownership engine started knocking as I set off on my work commute. Bypass poppet didn't save it.
**For newbies, pressurised oil (from the pump) enters the "shower head" perimeter holes in the baseplate then finds its way around the base end endcap to the outer surface diameter of the folded filter pleats - then passes through the media to the center core. Typically, there exist a good 2mm+ clearance (min.) here
Thanks EVERYONE!!!! I have been swamped this week and have not had a chance to read through all this but I will soon! Many thanks!
I feel your pain. Given this is the basic filter spec that is applied to most all: mazda, mitsubishi, mercruiser outboards, nissan/infiniti, acura/honda, subaru, Hyundai/Kia spin on canisters you would expect a plethora of choice, but recent movements in the industry have removed many good actors on the scene. Most recent was the Supertech (champ) MP line. Then the good wix numbers got hit.
I would look around to real local parts stores/suppliers that have WIX inventory and try to grab some USA parts before they are gone.
Mazda doesn't fool around, I would pay the asking price for this (wix direct cross to 57356):
Wix 57356
Mazda filter Bypass set at 23 psi WIX at 8-11 Psi better spec for Subaru engine
