Originally Posted By: Redpatches
I change my Odyssey's oil every 6 months with a quality synthetic such as Mobil 1 or Pennzoil Platinum plus a good quality oil filter. You can run either a 5W-20 or 0W-20 according to Honda. For the transmission you may want to do
a 3X drain and fill with drive cycle in between. That should hold you for about 30,000 miles. There is no ATF filter to change. ONLY USE Honda ATF-DW1. Should take little over 3 quarts per change. Also think about changing out the power steering fluid, brake fluid, coolant and spark plugs as
the car is over 80,000 miles. All are easy DIY fixes.
Actually it's 83,000km (~52000 miles). Coolant is the Type 2 Honda so it's good for a couple more years. Iridium Spark plugs are also good for a few more miles. I used Honda ATF-DW1 (1 dump/refill) for now and I'll do another on the next oil change. Also replaced PS fluid but didn't think of the brake fluid (thanks for the input!).
