2006 V6 RAV4 with 51000 miles. It started recently, couple of weeks or 500 miles. Only one wheel affected.
The brakes looked OK last time I did tire rotation (and bled the brake lines too) and soon after, it started. Initially only on cold brakes low speed, now it's all the time, but low speeds. Brakes stop the car fine.
I took them apart and don't see anything major.
You can actually see a reflection in the rotors. Groves are only minimal and don't catch a finger. Pads are fairly smooth and only slightly uneven. Slid pins were well greased with thick silicone grease (grease removed for pictures). There is some wear on the pins.
Should I replace pads and/or slide oins or just leave it alone?
