Originally Posted By: ItsuMitsubishi
This is almost unbelievable. M-V is not a special specification at all, despite what some heads might say.
M-V as a "spec" was chosen because it can be loosely interpreted as Multi-Vehicle or MerconV, which all Multi Vehicle fluids inherently conform to. Mercon V is nothing special either, it's simply the new Mercon, which was identical to Dexron III, which no longer exists. Heck, Dexron VI (VI presumably boasts it's Viscosity Index, and doesn't mean 6) can be used in most Mercon V applications without an issue, only differing in an Afton Chemical addpack over say Lubrizol and being 1cSt thinner, but more shear stable. I mean, the mainstream fluids are pretty much standardized without being officially standardized, causing manufacturers "make up" their own specification names for the "not using a competing brand's spec" reason.
Mercon v is not Mazda M-V:
https://bobistheoilguy.com/forums/posts/1628444/
I saw the above im few places around the net while looking for the correct fluid for my wifes 08 Mazda 3i.
I do agree that M-V is nothing special based on what I cleaned out of the pan. Actually IMO M-V is garbage!! No fluid should be that rancid,discolored and have that much sludge in the pan at 45k (about 80% highway miles, wish I would have done a UOA.
Actually did a drain fill with Castrol Import, then a week later dropped the pan for a filter and used Maxlife Dex/Merc. And after about 8k its working well, actually helped a 2nd shudder that the car would get going up a hill.
