Need advice on Lawn
One thing you have to remember, is even though the tree is gone, there is still residual root competition going on where the tree roots starved the grass roots of nutrition. You need to aerate the soil, use a surfactant too, and amend it with peat, mushroom compost, sand, and topsoil. Then feed the nutrients back into the soil with high phos starter fert and humic acid. Bermuda does NOT grow well from seed at all, plugs or sprigs will do better. Renovation with sod is the best, but then you could end up with different variety patches of Bermuda. Definately do a soil test, but I can tell by the soil color, it is acidic and needs lime. Also, we are entering heat stress and drought season so new growth needs water. A good soaking every other day should be sufficient. And tell the HOA to stuff it.
Scott’s starter fertilizer every 4 weeks will help the Bermuda grass spread more rapidly due to it’s phosphate content. Most lawn foods no longer contain phosphate and it’s essential for creeping grass.
It doesn’t have to be Scott’s. I’m using that as an example all home improvement stores also sell their house brands at a lower price. Just make sure when you look it says starter fertilizer.
Or in the case of Walmart, you can order a fertilizer called Texas fertilizer that also contains phosphate.
By the way, you don’t have to be starting a lawn to use starter fertilizer. It has to be sold this way because some states have banned the use of phosphate for regular lawn maintenance.
https://www.amazon.com/Scotts-Turf-Builder-Lawn-Food/dp/B00DK49DVA
I just bought some! Thanks!
I never had much luck seeding unless I used straw. Couldn't keep the area moist enough all the time without the straw to keep the sun from drying the area out.
1. Japanese Maple do not survive in full sun typically.
2.) You have waiting to long to plant new grass seed due to temperature. It is likely that you will kill the seed. But maybe not.
3.) Water, spread seed and feed, step on the ground to press the seed in, done. Then cover the area with straw to block a lot of the direct sun so the seeds dont get fryed.......and then hope.
