I just have about 2 hours on it but have a few questions. As I understand it needs 10w-40. I'm not sure if there's a particular brand that's required. Also regarding maintence, everything is in hours so I just wanted an idea on how that would compare to miles. Also wanted to see when to switch to synthetic.
Some details.
1500cc 4-cyl 4-stroke
inducted water cooling (should run cooler than a car/motorcycle)
7500 rpm redline. Probably spends most time at redline
And questions..
1) Can someone point me to a good oil "pump" there's no drain so the oil must come out the dipstick.
2) When to switch to synthetic.
3) At that point is Amsoil M/C oil okay (AMF)
4) Is it okay to run non synthetic car oil until I switch to synthetic ?
5) And last, would you recommend 10w-40 ? Would 15-50 or 20-50 be better.
Thanks in advance, I appreciate all the help.
Some details.
And questions..
