Should be pink in color since it’s 50/50. Pure red is straight coolant. I was going to get Zerex at AZ but it was the same price as Toyota pink.
Toyota Red is the older Long Life Coolant (5 years from the factory), Toyota Pink is the newer Super Long Life Coolant (factory 10 year interval, although my xB still has the original at around 16 now!). Red is available full strength OR 50/50, Pink SLLC is ONLY 50/50 from Toyota, but Recochem does make a full strength pink concentrate in their OEM brand-IF you can find it. Pep Boys had it in the past, but not anymore (here).Should be pink in color since it’s 50/50. Pure red is straight coolant. I was going to get Zerex at AZ but it was the same price as Toyota pink.
Reasonably close, should have similar, or at least compatible chemistry. I use Zerex Asian myself, but this sounds good enough.As others said my NAPA has it for $11.99 a gallon. I need the red in my older corolla. Yup I saw that PEAK was making it for NAPA.
Just wonder how close it is to OEM Toyota red?
You did indeed, and at an excellent price. Good call.Just noticed NAPA has it now for $18.99. Guess I got it on sale.
red and blue asian coolant are by far, the greatest, no rust whatsoever.Nothing but OEM Toyota RED for the 90k mile 1UZ in the Lexus (water pump passage and #2 cylinder):
I buy the concentrate and dilute 50/50 with distilled water.
prestone is good tooI see the manufacturer specific coolant at most parts stores now and I’m SURE its better than using the “universal, all makes” brand.
I would trust anything from Peak or Zerex that is targeting a specific vehicle manufacturers specs.
