Well I bought oil filter cutter on Amazon, and it wouldn't go small enough to cut a Nissan filter, and it ended up breaking..
that will be returned. First filter cut open was a (Napa pro select it had 60 pletes, nitrile rubber anti drain back valve it came off my 2013 Ford Edge 3.5, it only had about a thousand miles on it, reason why I took it off was because I just did my water pump, timing chains and the components also the oil pump. So I just wanted to get all the metal out of there. Oil that was in there was 5W20 Napa full synthetic, oil that went back in, was Mobil 1 5W20 with a WIX XP filter
