Originally Posted By: mobilaltima
Originally Posted By: exranger06
The pre-cat is falling apart and the broken chunks are getting sucked back into the engine, which is ruining the cylinder walls and piston rings and making the engine consume oil. It's a common problem with the Nissan 2.5s and there was a recall for it.
my 2002 altima came up with P0420 code one day (catalyst efficiency) which meant the pre cat was going bad. Ordered a header and installed it myself, fixed the problem before it started burning oil.
Then 'you may' have been one of the very few lucky ones, because when the SES light showed and corresponding code 0420 on my well maintained 03 2.5L Altima, the precat had already puked and the particulates had scored the cylinders resulting in excessive oil consumption and an terminal engine condition.
And iirc, your engine began to lose/use antifreeze mimicking the the signs of a blown head gasket. That is also a sign of failed precats damage. As the youtube may not meet bitog standards I won't post it but if one googles ....
How can pre catalytic converter parts get sucked back into an engine .... and the first choice should be the yt showing this condition and the precat damage.
Having experienced precat failure personally I posted a detailed thread on the topic linked below. If interested, all one might want to to know.
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2139188&page=all
And Nissan's 2.5L precat recall, a free oil and filter change, was completely bogus. It did nothing to prevent eventual precat failure and the engine terminal condition.
All that said, not saying that's the OP's issue. Without an SES light and corresponding 0420 code, may not be. Nissan also had an issue with defective piston rings and excessive oil consumption on some 2.5L, but iirc that seemed to occur early on in new ownership.
