Originally Posted By: CATERHAM
TGMO 0W-20 is an entirely different formulation to Mobil 1 Extended Performance or Mobil 1 Advanced Fuel Economy 0W-20.
Yes, I think we are both saying that. They've leveraged a Group III base and a healthy dose of VII's to get the product's high VI, which was their design goal. Mobil's branded products are using superior base oils and lower VII treatment rates because they obviously have different goals. A stratospheric Viscosity Index is apparently not one of them.
It's formulated to be as light as (economically) possibly at more typical start-up temp's and in that regard it is far lighter than Mobil 1.
As we've discussed before, you and I have two very different ideas of what constitutes "far lighter". TGMO is ~37cSt @ 40C, Mobil 1 0w-20 is 44.8/9. That 8cSt is insignificant compared to the difference between either of those oils @ -15C and your typical OTC 5w-20, which is in the hundreds of cP. And compared to even the AFE 0w-30, which is ~63cSt @ 40C, which I would have a hard time referring to as "heavy" under these circumstances given that your middle of the road 5w-40 like Delvac 1, at two grades heavier, is 102cSt @ 40C. 3x heavier? OK, yeah, Mobil Delvac 1 5w40 is far heavier
The base oil composition is a non issue as long as it's VI is sufficiently high enough to achieve Toyota's goals. And some GP III+ base oils have higher VIs than PAOs of the same viscosity.
Since TGMO is undoubtedly using a 4 cSt base oil, likely no PPD's are used in it's formulation.
Well, this is BITOG and base oil composition is always an issue, LOL!
We know PAO is more expensive than Group III and generally requires less treatment to achieve the necessary viscosity characteristics for a grade split. Member bobbydavro gave a really neat example (in the following thread) of an oil with the following characteristics:
Kv100 7.72, kv40 42.42 (density 0.85) with a HTHS of 2.61. NOACK of 4.4% but a VI of 152. This is a 0w-20 with ZERO VII's in it! Pretty cool.
If you missed this image from that thread:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3625715/Re:_High_VI_and_Base_Stocks#Post3625715
I suggest giving it a read.
You'll note your 4cSt group III base oil (or at least the one referenced above) has a pour point of ~-25C, so it would definitely need PPD's. The comparable 4cSt PAO has a pour point of -60C.
Note that Mobil's Spectrasyn Lo-Vis 4cSt PAO has a pour point of -66C and a flash of 220C. It's VI is 126. Their Spectrasyn 8cSt PAO has a pour point of -57C, a flash of 246C, and a VI of 139. Oh, and the latter has an MRV of 16,200cP @ -40C and a NOACK of 4.1%.
Now, I'm not sure how current this is but based on the CAS # for the Group III base (listed as 70-80% in the MSDS for TGMO) as "SEVERELY HYDROTREATED HEAVY PARAFFINIC DISTILLATE": 64742-54-7
Molakule posted the following:
Originally Posted By: Molakule
Mineral Paraffininc Base Oil - 64742-54-7; VI of +94 to 120, any group.
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=257884
This CAS # also does NOT seem to correspond with a 4cSt base oil, FWIW
