Originally Posted by bullwinkle
Originally Posted by clinebarger
I know it sound bad.....I've seen every failure imaginable on GMT800 trucks. They're really good but have quarks. Not any one truck will experience ALL these failures.
I hate to hijack, but, how many of these failures would apply to an LQ4 6.0 (in an '06 3500 van)? Thinking about retiring my GMC 6.2.
All besides the Intermediate steering shaft, Parking brake, '05 & up had better fuel pumps & Clusters, Intake gaskets were updated (E-85), No trans drain plug post 2004. Van engines don't normally get washed, So the knock sensor wells are usually dry.
You'll have to check if it has a Kelsey Hayes ABS unit......Vans are known to use Bosch units that don't have the cold solder joint issues.
The vans use Vacuum actuated HVAC actuators......The vacuum hoses in the engine compartment are known to deteriorate in @ 10-12 years.
4L80E's like to leak ATF through the pass-through connector, Replace internal harness if leaking.
