Your car has the dreaded Hyundai turbo hamster.
youtube
youtube
I definitely will. On my other 2013 Santa Fe, I'm about to have them change the oil with the same Amsoil SS 5w30 but I'll be trying an Amsoil oil filter. This Santa Fe doesn't have a squeal or significant engine vibration, so I'm not sure I'll glean anything useful from the exercise. Keep in mind this other identical Santa Fe has seen the same oil and filters as the noisy one.I think you’ve found a combination that you like, and that’s what really matters.
Fanboys and haters exist for every brand. Brands of oil. Of trucks. Of everything. Most of those two groups have no real reason for their cheerleading or hatred, so I ignore most of them.
There are a lot of good oils out there. I have some real world experience with Mobil 1. I’ve posted photos on how clean the inside of my V-12s are, you’re welcome to search, and the 0W40 performed well in UOA for those engines. Pennzoil Ultra Platinum has kept the inside of my Tundra clean. None of those engines have any issues and none of them use a drop of oil. I’ve got several cars running HPL - and so far, I’m impressed.
Buy what makes you happy. Call it good.
Definitely keep using that Bosch filter if you do choose to change oil brands - manage the variables for a more accurate comparison.
That it does! Luckily, Hyundai has been great about any warranty items and even certain things that were just outside of warranty. Now I'm just trying to make these engines last as long as I can.
I cannot be sure other than these indy shops have good reputations. It's entirely possible they didn't change what they said they did. I suppose it's easier to check the oil filter since it's more visible. Regarding the oil, I'd have to do an analysis.Another question. Who changed the oil and filter every time and are you SURE the indy shops actually changed the oil and used M1? There are numerous tales of shops either not doing the oil change or using a inferior mislabel oil...
So can you be sure the oil and filters were in fact changed each time?
Okay, now you have 3 variables in the mix.Oh, one other detail I forgot to mention...I did recently switch from Shell 87 to Shell 93 octane gas. I did this given some people have said it helps with fuel dilution and carbon build-up. No idea if it was a contributing factor though.
Agreed. I won't mess with this combo given it's made such a difference.Okay, now you have 3 variables in the mix.
As for filters, I believe Napa parent filter is Wix and generally identical filters, which are top notch filters. However there might be a design difference between Bosch (also top notch filter). You could try to find videos of these filters cut open or buy a few yourself to cut open to inspect/compare.
But this is academic. You've found a good combination of oil, filter, fuel to eliminate the noise so may be best to stick with it.
Yeah, that's one of the potential issues of a "real life test".Oh, one other detail I forgot to mention...I did recently switch from Shell 87 to Shell 93 octane gas. I did this given some people have said it helps with fuel dilution and carbon build-up. No idea if it was a contributing factor though.
I always said Mobil 1 was a very vocal oil. It's all on here...
Well, this wasn't mean to be a scientific model. I don't have that kind of patience or time.Yeah, that's one of the potential issues of a "real life test".
Just form a conclusion based on what you have seen regardless of what may have changed
Thanks! I'll keep an eye on things and see if anything changes. On purpose, I had the dealer formally analyze the squeal before my 100K mile mark JUST in case something fails and I can perhaps use that to get warranty coverage if the turbo goes out.Perhaps removing the intake at the turbo, and feeling for excess play on the spool might indicate a bearing issue. Oil taking a second or two to mask the sound. I’d do that just for fear of it grenadine and taking the engine with it.
I recently started running M1 ESP 5W-30, which is supposed to be thicker, and I didn't notice a change in noise (was running Valvoline 5W-30 EP before that).It was a bit of humor but there are pages and pages of posts like that on here. They usually end up in fist fights though.
Sorry, not you. For the topic starter.Disregard.
Yes and I suppose their product is 100x better? Give me a break. Not much of a ROI.Consider that M1 spends something like 100x R&D budget that Amsoil does
