H. Swanson
- Joined
- Jul 22, 2023
- Messages
- 194
I do change the oil at the prescribed OCI. I don't use fuel additives because I always use Top Tier gas. For more than a year, I exclusively use Shell 93 at every fill-up.I have the 2014 model of your Santa Fe in my family (son's car). I've maintained it since new.
Do you do the Hyundai-recommended Techron fuel system cleaner at every oil change interval? If not, this is a MUST for these engines. I don't always use the Techron, but I do use Gumout Complete Fuel System Cleaner instead--I believe this is roughly equivalent to the Techron product. Either will keep your fuel system in good shape.
As for oil, I think these Hyundai's (especially the turbo versions) are perfect candidates for Valvoline Restore & Protect oil. I intend to convert my Hyundai vehicles over to that as soon as I use up my older oil stash. Also, if your PCV hasn't been changed recently, I'd recommend doing that ASAP. Spark plugs?--If they haven't been changed in the last 30,000 miles, I'd recommend changing them ASAP. These engines don't require a lot of maintenance, but it has to be done on time. Good luck!
I'm intrigued by Valvoline R&P. I may try it for the new handful of oil changes.
