17 Civic 1.5T, 115K mi, Pennz Euro L 5W-30, 7K OCI
Wellington, Florida
Changed the oil a little early this time around, meant to go 9K but was under the car changing the CVT fluid so did both at the same time. Driving habits typically do not involve short trips which helps minimize (so the boards say) the fuel dilution issue with these engines.
Whether I use Euro L, PP or PUP, this little engine seems to "like" it. So next ODI will feature a mixture of these oils... but not deliberately. I thought I had Euro L in my inventory but after draining the oil, I discovered I was just about out of Euro L. I intend to use PUP 5W20 going forward in all my cars (except the Porsche) so decided to use up the Euro L and PP I have lingering in my cabinet, so here's the mix:
- 2.0 qts PUP 5W30
- 1.4 qts PP 5W30
- 0.3 qts Euro L 5W30
... and a 7K OCI, that is if I remember t change it in time.
As I type this, and look at the recent history, does it appear that 5W20 performed better than the 5W30?
The iron wear is what's drawing my attention. I inserted a row into the spreadseet to show iron wear as PPM per 1K miles and you can clearly see the difference. I'd like to hear what the more seasoned and knowledgeable members have to say about this, and I'll take all feedback and recommendations.
At this point, I'm going to change the oil early at 5K and start using 5W20 @7K OCIs. I'm going right back to PUP but will look into PP High Mileage as an option as well.
There is so little variation in your data that it isn't significant. We have no way to know how much lab error is in your data, so there is no way to account for it and there is lab error. No UOA data is 100% accurate.
The average Fe is 1.62 so 2.06 is only 0.44 ppm/1k miles above the average. There is no actionable data here.
Until you have a good trend, I wouldn't change anything.
- 2.0 qts PUP 5W30
- 1.4 qts PP 5W30
UOA is analysis of oil not engine. Only time you can figure something is going with an engine is if you wear is 10ppm, next time 20, next time 30ppm etc.
What you have here could be product of more city driving, colder weather, oil leaching more metals bcs. certain additives or base stocks.
Fuel additive from what others have said
I believe @chinee has said in the past they do not use fuel additives. That would mean it would be coming from the fuel they are buying. So is there something about Florida that they are adding Manganese in their fuel but no one else's? What I mean is I haven't seen elevated Mn in any other UOAs on here that can be traced to fuel from the pump.
No, I do not use fuel additives, but I do add Chevron fuel system cleaner from time to time. Could that be the source of the Mn? Odd that it's only appeared in the last 3 UOAs.
And yes, I do have a preference for Pennzoil, it worked well in my old Sequioa in the 2000's before I switched to Halvoline HM, which also did a great job in the engine. And the Pennzoil seems to be performing in these engines as well, so it's won my loyalty.
I don't think Chevron fuel system cleaner is the source. I've used Techron Concentrate Plus regularly and have never seen my Mn results climb. Looking at my UOAs, my 18 CRV (which has the same engine as your Civic) has varied from 1-4ppm Mn over 7 UOAs. My 03 Civic has been between 0-1ppm Mn over 12 UOAs. And my 13 Volvo S80 has always gotten 1ppm Mn over 4 UOAs. I wonder if it's a fuel formulation change specific to your area in Florida?
Not likely the fuel in my area... just checked the UOAs on the other 2 cars in the household and there's no Mn. But we all frequent different gas stations, so the oddity and possibility of the Mn in the fuel remains. I did change the PCV and spark plugs on 8/20/24, 2 days before the Mn appeared, could the Mn come form the plugs? I doubt that...
