- Joined
- Nov 29, 2009
- Messages
- 10,258
Is this a good method? Just cover the air cleaner and distributor cap, then hose it down eith a garden hose sprayer attachment. Then after that take said machine out for a drive so dry off any water as I dont want any water sitting for any period of time. Then respray with anti corrosion spray. I like to use a marine grade spray that leaves a glossy waxy coating. The problem is the dust gets caked on and it needs to be washed off and re applied.
