Originally Posted By: SubLGT
Summer tires (and UHPAS) do not necessarily lose major amounts of traction at low temperatures:
http://www.caranddriver.com/features/09q4/2009_winter_tire_test-comparison_tests
http://www.zr.ru/a/16286 (use google translate. Take a close look at the graph and chart).
I think you are safe with "average" summer tires. But not so safe with the "ultra high performance" summer tires.
Also see this discussion:
http://legacygt.com/forums/showthread.php/change-winter-tires-145259.html
Good links, thanks. I forgot about that C&D test. It's too bad they didn't put a summer tire in the mix!
In that test and in the Russian test, the summer and all-season tires easily outperformed the winter tires down to -5C in the absence of ice and snow. So it really isn't an issue of the rubber being too hard for good traction on pavement, it's a lack of siping to help avoid building a layer of ice on the tire under certain conditions. The Russian site sort of explains this.
Originally Posted By: Russian Site
At a temperature close to zero (from the "plus"), grip summer tires are still pretty high. . . A temperature of +7 ° C tire manufacturers indicate a margin to avoid a likely meeting with icing . . . As a rule, the better they behave on snow and ice, the less tenacious on the asphalt . . . The frost below -5 ° C it is particularly smooth, very crafty: when braking instantly "sweats" in the contact patch, and a thin layer of moisture on the cold, immediately turns into an icy crust. So that when the frost is strongly recommended to replace tires for the winter, even if the road is absolutely clean from snow and ice. On roads with rough asphalt, this effect is less pronounced.
Translated Link
It seems like it really would be best to get some high performance all-seasons on that BMW if it will be used below freezing temperatures, but you can drive on anything if you're careful and aware of the road conditions.
That Legacy site looks like a good forum. I didn't read through the whole thread yet, but I will.
