Multi-purpose Car Lube question
IN
I am looking for a long lasting multipurpose spray lube for door hinges, and the little lever that opens and closes the fuel door (06 Honda Civic) What options do I have material (chemical composition) and what brands types do you recommend based on your experiences. Thanks!
Gee, just about anything in a spray can!
Probably white lithium grease!
White lithium spray grease.
If its getting hard/drying out you got a bad can as I have never seen that from spray white lithium grease.
Have an old can of white lithiun grease from my dad's workshop-it must be 40 odd years old and looks like new!
I've had good results with many lubes for door hinges.
-Liquid Wrench Lubricant with CERFLON
-Triflow oil
-Fluid Film
-Probably many more
I'm sure some last better than others but I don't consider it a very demanding application. Heck I bet regular silicone spray would do the trick too. Or any given liquid oil dripped on.
I use motor oil on the tip of a screwdriver or 3 in1 oil with the little applicator for those things. I've used spray grease before and it never works out for me.
GM sells a product called Spray Lube specifically for door hinges, hood latches, etc. It also works on Fords and Subarus.
