Originally Posted by Gokhan
>> KV100 has no significance. span>
Only the base-oil viscosity and HTHS matter. KV100 does not matter. M1 10W-30 has a lot thicker base oil than M1 5w30. The only reason M1 5w30 has a higher KV100 is because it has a higher VII content, almost twice that of M1 10W-30.
As a general rule, you want the lowest KV100 for a given HTHS for a thicker base oil, which results in less engine wear. M1 10W-30 would result in less engine wear than M1 5w30 because it has a thicker base oil.
M1 10W-30 would also exhibit only about half the permanent shear (permanent viscosity loss) M1 5w30 exhibits because it has only about half the VII content of M1 5w30.
The discussion was about using a "thicker" 5w30 to combat the viscosity lowering effect of the fuel dilution that the Honda 1.5 turbo is known for and 10W-30 was suggested. A couple of us mentioned that in some product lines the 5w30 is a little thicker than the 10W-30, and I used M1 as an example. No one was debating which one provides the best wear protection, I think most would agree that the 10W-30 would probably win that contest. So the question is, which is better for countering fuel dilution, a 5w30 with a viscosity of 11.1 or a 10W-30 at 10.4 cSt? The other question I would have is whether it's even a good idea in the first place to use something other than the recommended 0W-20?
I'm interested in this because I'm looking hard at the 2020 CR-V as a replacement for our HR-V but I can't find any solid evidence that the fixes Honda has tried the last couple of years has actually worked.
It doesn't matter. Engine oil is a non-Newtonian fluid, which means its viscosity changes with the shear rate.
KV100 is the low-shear viscosity. There are no low-shear parts in the engine, except for the leak paths. For everything else either HTHS (high-shear with partial VII shear) or HTFS (full-shear (base-oil + add-pack viscosity) with full VII shear)) applies. Note that shear in this context refers to temporary shear, not permanent viscosity loss.
So how does the same amount of fuel dilution affect KV100, HTHS and HTFS when comparing between a 0W-20, 5w30 and 10W-30 oil?
Which oil would be best to use in an engine known for lots of fuel dilution?
