Motul Specific LL01-FE 5w-30 for BMW S55
they put LL01-FE on my 1200 mile break-in service, i believe they are doing LL01-FE even in M engines, someone correct me if i'm wrong? i know for sure they (the BMW dealer) put the FE oil in my car.
I'd just use TPT 5w30 and perform a used oil analysis at 5,000 miles. I suspect that a 10,000 OCI is perfectly fine.
BMW dealers do all kind of stuff. And yes, they are all gun hoe on fuel efficent oils.
Your engine is built with LL01 in mind and in your manual you can find where it says that you can use LL01 if you are concerned about warranty.
You do not have to change oil at the dealer.
If LL01 is in fact going away & being replaced by a LL01 FE, are NA engines missing out on anything with the FE oils vs plain old LL01 ?
BMW recommends LL-01 FE 0w30 for this M engine. There is no mention of LL-01 anywhere in the owner's manual.
2019 BMW M4 owner's manual
LL-01 FE is basically ACEA A5/B5 with TBN ⥠10.0. Therefore, I think any flagship ACEA A5/B5 5w30 would do well in this engine. Mobil 1 5w30 and Mobil 1 Extended Performance 5w30 are both ACEA A5/B5 and have TBN ~ 10, and they would be excellent choices for this engine, the Extended Performance version being even better.
BMW makes a lot of money from dealer-provided services. I wouldn't hesitate using Mobil 1 FS 0W-40 and Castrol 0W-40 for LL-01, Mobil 1 5w30 or Mobil 1 Extended Performance 5w30 for LL-01 FE, and the PAO-based Mobil 1 Extended Performance 0w20 for any Euro-OEM or ACEA C5/C6 0W-20 spec. These oils are very cheap at Walmart, and I bet they outperform the BMW "Twin-Power Turbo" OEM oils in any application.
S55 engine is developed from N55 engine. Again, stop with your "recommendations" that are based on your Google knowledge. N55 engine as well as it's cousin, S55 engine is developed around heavy oils, LL01. If owner is going to use any other oil, it should be LL01, and not Mobil 1 Extended Performance. BMW NA only recommends FE oils in last few years. LL01 oil was recommended before for the same engine. Change is due to CAFE requirements and does not have anything to do with engine design:
Page 185
https://carmanuals2.com/get/bmw-m3-2016-owner-s-manual-83032
Also, LL04 (HTHS above 3.5) is only recommendation for S55 engines in Europe.
And no Wal Mart oils like EP etc. do not outperform BMW TPT. You bet wrongly.
Again, stick to Toyota.
Page 185
You said the OP shouldn't use LL-01 FE in his engine and the dealer put the wrong oil by using it. Should people follow recommendations by an accountant like you with minimal technical and scientific understanding of engine oil instead of following the recommendations in their owner's manuals?
Engines have many versions. You don't know if the newer versions have better oil cooling among other things. Most new BMW, Audi, Jaguar, etc. engines spec 0W-20, and there is engineering research and development going into that.
The oils I suggested are very similar to the their BMW OEM counterparts. Castrol and Mobil 1 are not "Walmart oils." You can shout as much as you want that BMW OEM oil is better than Mobil 1, but you have zero backing and zero understanding of it.
Driving a BMW makes you as much an oil expert as using an iPhone makes you an electronics expert.
Stick to accounting.
BMW TPT 5W30 LL01:
http://pqiadata.org/BMW_5W30.html
And? Noack is very low because it barely passed the CCS test.
BMW Twin-Power Turbo 5w30 LL-01 is almost without a doubt identical to Pennzoil Platinum Euro 5w30 LL-01. Yes, the former is also manufactured by Shell in the US. Their KV values are virtually the same and their CCS values are very similar. I ran them in my calculator and the VII content and base-oil viscosity (HTFS = BO DV150) came identical between the two. They are also similar in base-oil viscosity and VII content to Mobil 1 ESP Formula 5w30, which was more "stout" as BITOG'ers would say than Mobil 1 ESP 5w30 that replaced it, albeit these ESP oils being mid-SAPS (ACEA C3) oils.
They are very good oils, blended with a very thick base oil, which I like for lowering wear. 2.6 cP is a very high base-oil viscosity for a 5w30. The base-oil type would be GTL, suggested by the low Noack value; however, the reason it is that low is because the CCS viscosity is right at the upper passing limit (6,600 cP at −30 °C), which means these oils are almost a 10w30 and can probably be labeled as a 10w30 according to SAE J300 viscosity-spec rules—there is nothing wrong with that unless you are in an extremely cold climate.
I also ran the calculation for the mid-SAPS Pennzoil Platinum Euro L 5w30 LL-04—a Walmart oil
—and its base oil is only slightly thinner and VII content is a bit higher. It is a good oil, too. A few years ago they had an older version that had a significantly thinner base oil and a significantly higher VII content.
>> Automated calculator for the A_Harman index, VII content, and base-oil viscosity a>
A little history on the S55. BMWNA has been all over the map for this engine with regards to viscosity. Initially it was 0w40* then 0w30. M-owners were getting hung up on viscosity because depending on the MY the under hood sticker would state either 0w-40 OR 0w-30. Of course the owners manual specifically states only 0w-30/40. No 5w30/40!! In any case if one goes by the manual then they are limiting themselves to just a few oil choices. Basically the S55 is spec'd for HTHS of 3.0 or higher with a viscosity of 0w-30/40.
*There used to be a TPT 0w40 sold at the dealerships.
BMW TPT 5W30 LL01:
10w-30? Interesting. I never thought about that.
Quote
Yes, he should run LL01. If I had that engine I would run LL01. I was actually not aware that that year switch to LL01FE only, as S55 was always LL01 engine. But then actually, I know how that engine looks under the hood, unlike you. S55 did not go through various versions. Just to say that tells actually how ignorant you are about this subject., yet you find appropriate to give "advice" everyone. You are talking about manual above, and then recommending Woodo oils from Wal Mart. I have backing of BMW approvals and not some insecure wanna be. To say that I do not have backing that BMW oil is more superior for BMW application than oil that is not approved or at least recommended for BMW by oil manufacturer, really shows how much interaction with people you have, bcs. you are really bad in discussion business.
Stop recommending people what to use as you absolutely have no clue what you talking about, and go back and figure which Mobil 1 0W40 is SM and which SN.
Nope, you are the one who have been making recommendations based on personal bias and misconceptions, like without knowing what the actual recommendation for a given BMW model is and making the blanket LL-01 recommendation for any BMW gasoline engine.
Yep, the CCS viscosity for BMW Twin-Power Turbo 5w30 LL-01 is right at the 5W-10W border (6,600 cP at −30 °C).
Yep.ALL BMW gasoline engines are recommended for LL01 and LL04 (depending on market). But, this is higher math for you.
Again, Toyota.
Again, Toyota.
If your children fail math, you should buy a BMW for them, like when your parents did for you.
