Vehicle:
06 Scion tC, 2.4L, 4-cyl (2AZFE)
Oil:
Motul 8100 E-Tech Lite 0W/30
Oil additives:
None
Make up oil added:
None
Engine oil capacity:
4 quarts
Oil filter:
Mobil 1 EP 103
Air filter:
K&N direct replacement (cleaned at 20k)
Miles on oil/filter:
10,002
Miles on vehicle:
30,002
UOA by Blackstone Laboratories:
Elements in PPM:
Aluminum: 3
Chromium: 1
Iron: 18
Copper: 4
Lead: 3
Tin: 0
Molybdenum: 17
Nickel: 2
Manganese: 1
Silver: 0
Titanium: 0
Potassium: 1
Boron: 69
Silicon: 31
Sodium: 9
Calcium: 3000
Magnesium: 207
Phosphorus: 936
Zinc: 1151
Barium: 0
Properties:
SUS Viscosity @ 210 F: 58.3
cST Viscosity @ 100 C: 9.73
Flashpoint in F: 395
Fuel %: Antifreeze %: 0.0
Water %: 0.0
Insolubles %: 0.3
TBN: 2.3
TAN: N/A
ISO Code: N/A
COMMENTS:
The only unusual find here was silicon, which isn't really that high in the grand scheme of things. Silicon can come from several sources, including dirt getting past the air filter, sealers, additives, or silicone-based lubes used elsewhere in the engine. in the case of sealers, additives, or lubes, silicon is harmless. Wear was fine so we dont think the silicon came from dirt, though we'll keep an eye on it next time. We found no sign of any gas, moisture or antifreeze in this sample. The TBN read 2.3, still some active additive left. Try 12,000 miles next.
Oil:
Oil additives:
None
Make up oil added:
None
4 quarts
Oil filter:
Mobil 1 EP 103
Air filter:
10,002
Miles on vehicle:
30,002
Elements in PPM:
Aluminum: 3
Chromium: 1
Iron: 18
Copper: 4
Lead: 3
Tin: 0
Molybdenum: 17
Nickel: 2
Manganese: 1
Silver: 0
Titanium: 0
Potassium: 1
Boron: 69
Silicon: 31
Sodium: 9
Calcium: 3000
Magnesium: 207
Phosphorus: 936
Zinc: 1151
Barium: 0
Properties:
Water %: 0.0
Insolubles %: 0.3
TBN: 2.3
TAN: N/A
ISO Code: N/A
COMMENTS:
