I have no idea how many bearings you install in motorcycle wheels in your shop. But please don't over simplify this as something simple. No one in my shop is going to pound.A bearing into a two thousand four thousand dollar wheel. Some of these lightweight wheels are as thin as 4 to6 millimeters. On the outside of the bearing hub. You can watch the pressure on the press. I do not agree with heating the hub due to I do not know the composite of the aluminum. Nor do I have a degree in metallurgy. But freezing the bearing allows it to be installed with as little as 200 pounds per square inch. Same wheel, without freezing the bearing will sometimes exceed over a thousand pounds per square inch. These expensive wheels are very.
Common in southern california.
