While i have not done MC bearings, i have pressed sealed bearings in to hubs, so similar just bigger.When pressing a new sealed bearing into a MC wheel, are there reasons to/not to lightly oil the outer ring of the bearing so that it installs more smoothly?
(I am not talking about adding extra grease to WITHIN the bearing)
X2heat the hub/freeze the bearing
Oiling is okay. My anal retentive nature would be to make sure there are no burrs or debris on the surfaces to hang up the installation.
X3. Heat hub/freeze bearing.
I use a small wipe of Moly grease on the outside of the bearing.
Just be aware that some motorcycle wheels have a bearing installed full depth on one side and the other bearing installed to the depth that the inner race is up against the spacer. The outside of that bearing might not be full depth. In other words you can't always just hammer/press both bearings in until the outer race seats.
No need for motorcycle wheel bearings. They go in easily with light taps from a hammer.X3. Heat hub/freeze bearing.
That’s a broad brush you’re painting with!No need for motorcycle wheel bearings. They go in easily with light taps from a hammer.
And saying “freeze it” without any other information isn’t? It actually makes the moisture condense and then freeze on the bearing. That water can get past the seals. So it’s not some universal solution either.That’s a broad brush you’re painting with!
I’ve not done as many as some people I’m sure but I’ve done probably 50-70 motorcycle wheel bearings and I’ve seen some VERY tight interference fits that were way beyond “a few light taps”.
With respect freezing the bearings and heating the hub is a time tested and no downside procedure.No need for motorcycle wheel bearings. They go in easily with light taps from a hammer.
Plus I don’t think any of the service manuals I’ve seen call for it either. They all mention driving the bearing in.
