F150 wheel bearings
West Michigan
Wheel bearing hub assembly has developed a growl so gotta throw a new one in. Going to pick up an SKF from rockauto... Anybody know for sure what type of grease these are lubed with during assembly? I'd like to add some to the pilot needle bearings just because they are wide open during assembly. I'd also like to pump more into the main bearing through the ABS hole- I did this on my 2011 many years ago and still have the original bearings up front without any issues....
I would think its almost 100% a lithium grease, but then again its not worth gambling on grease incompatibility either...
Just make sure you don't order SKP bearings by mistake. Don't ask me how I know, LOL.
I would not add grease to a hub bearing in any way. You will destroy the seal to keep the grease in and likely introduce a grease which is different and will break down the grease inside the hub assembly. Also, too much grease can be a bad thing.
Adding grease will more than likely lead to an overgreasing problem and cause excess heat and lead to premature wear.
