I run the 400s on my B&S commercial turf engine in my Ferris ZTR, because of the way a couple cables are routed down by the filter, the 400 is actually easier to get on than the OEM filter is.Good Briggs & Stratton oil filter for way less $
Yeah, I’m already tight on mine since the OEM puts a yellow stubby over priced filter thereI run the 400s on my B&S commercial turf engine in my Ferris ZTR, because of the way a couple cables are routed down by the filter, the 400 is actually easier to get on than the OEM filter is.
Not lucky. The 910 is a very fine filter. I've been using them for 10+years in my Fords and they always look this even with my normal 10K OCI.It was off of my Fusion, actually. Good guess though, we have a Focus as well (parents car), and it was using an FL-910S until recently.
Looks better than I expected; was half-expecting to see something up with it, based on some of the posts I've seen here about Motorcraft filters. Maybe I got lucky.
I have used the 910 on my 8 year old Craftsman rider with the 21HP engine. I change the oil and filter every 2 years and the filter always looks great.I use the 910s on my B&S powered lawn tractor and also on my Kawasaki powered zero turn. Too bad it won't work on the Frontier.
The 2008 Escape take the FL820S so I am glad to know these are good filters. The 1994 Econoline takes the FL1A. I will continue using them I only use mine for 3000
No. I haven’t they are great filters from my experience.Guess you haven't seen all the torn Motorcraft FL-820S threads.
That’s strange though that it would be just the 820S ones I have searched here and am seeing that more I wonder if something is used differently in theseJust saying ... of all the cut open and posted Motorcraft filters, the FL-820S has shown sporadic media tearing issues. They can and do tear if the pleat spacing is bad, just like any other oil filter can.
Oh ok I didn’t know they had the longer version of that one. That makes sense why it would do that.The 820 is the longer version of the 910. Longer pleats, and too wide of pleat spacing puts more stress on the media at the ends where it's glued to the end caps. That's where the media can tear as the oil flow force bends the pleats over. The 910 cut and posts show that the pleats are typically spaced tighter at the seam than the 820.
Nice. On my Escape since it’s my dads he won’t let me use anything else but the 820S so I couldn’t put the 910S he thinks the taller the filter the better it is lolYes the 820's on the outside look spectacular. They aren't on the inside.
The 910 is great as others have noted.
I use them on ope and my Cmax.
I am not sure which one it is. When I look it up on google, the auto parts store site and rockauto it all shows the 820S for the V6 engine. I’ll show him but he rarely changes his mind and gets angry about it lolShow him some torn 820s and he might change his mind. The Escape engine isn't gaining anything from the longer 820 unless maybe if you're doing extended OCIs. I believe the 910 is what Ford specifies for the Escape.
This is correct. A FL-820 is a much larger diameter than a FL-910.I thought the FL400 was the long version of the FL910?
What the MC/Purolator’s have in common is weak paper media … I cut open several and it’s just weak - full stop.Just saying ... of all the cut open and posted Motorcraft filters, the FL-820S has shown sporadic media tearing issues. They can and do tear if the pleat spacing is bad, just like any other oil filter can.
