MaximumMini
Thread starter
- Joined
- Apr 13, 2025
- Messages
- 319
Most oil filters are rated to take well over 200 PSI of internal pressure ... some more like around 250-300 PSI.
So if you saw 60 PSI with hot oil and well over 3,000 RPM, then that sounds pretty normal.
40 PSI at what RPM going down the highway.
I highly doubt it's going to be 140 PSI with hot oil (or even cold oil at higher RPM) unless the pressure relief valve is not working right.
I meant 140psi for bursting pressure. Sry.
Usually at around 65 the rpms are around 1600-1700 rpm IIRC.
